weight reduction, race ready ?
thx
He is in the process of building a 2500 pound C4 *with a cage* in it.
The thread has been going on for a long time, you shouldn't have trouble finding it here in C4 tech.
I stripped most of mine down but didn't add lightweight panels or glass yet. I'm at 2900 with no interior, no AC / heater core, lightweight flywheel and balancer, etc. Check out
<------my corvette pics
to see interior gutting.
Mine is a RR car so I need stiff swabars, big tires, and brakes, but you can save weight there if you're not going to drive on the street.
Good luck, feel free to ask or PM me for more info once you get started.
-Jon
Also, there is the consideration that in a lot of bracket racing events you must have the stock interior right down to the carpet...
You may have misspoken and meant heads up...if you did it is a whole different story...
thx
Here is a very short list of ideas:
1. Remove factory exhaust & replace with full length headers.
2. Remove under bumpers the crash absorber honeycomb.
3. Remove heater, heater core...
4. Remove A/C unit and all A/C crap.
5. Remove smog pump crap.
6. Remove power steering pump and loop the line.
7. Remove computer and harness if you are going carb.
8. Swap in a light weight battery...10 to 25 lbs easy.
9. Swap in a starter...worth 5 to 10 lbs easily.
10. Swap in a lightweight waterpump.
11. If you car didn't come with aluminum heads...35-40 lbs savings.
12. Swap rear window with a lexan unit (buy a used hinge plate)
13. Gut gut the underside of the dash including the air ducts.
14. Remove the breakbox if you have one.
15. Remove the center console,
16. Remove all carpeting and padding/sound deadener.
17. Remove the stereo and speakers and wiring.
18. Swap factory brakes with Aerospace units with aluminum hubs.
19. Swap to an block.
20. Remove cargo boxes in rear and rear shade.
21. Replace factory seats with race seats.
22. Remove factory seat frames especially the power ones.
23. Melrose room skin (very light)
24. Toledo Pro lightweight race hood skin.
25. Melrose front and rear fiberglass bumpers (lighter).
26. Do away with head lights, motors, gears & dzus light covers.
27. Race wheels like Weld Magnum, Alumastars or Bogarts...
28. skinnt fron tires, race drag tires WITHOUR tubes.
29. Titanium wheel studs.
30. Rifle drill all non critical fasteners.
31. Harry Glass carbon fiber dash.
32. Aluminum fasteners/titanium fasteners.
33. 7 or 8 inch torque converter.
34. Powerglide will save a ton of weight if your car is really light.
35. Cromoly roll cage.
36. Replace windshield replace side windows with lexan.
37. Gut the doors or at least the crash beam.
38. Race radiator with aluminum mounts.
39. Remove front sway bars.
40. Lightweight coilover shocks, remove front spring and trim frame.
41. Fuel cell and lightweight fuel cell mount.
42. Obviously remove spare tire, spare mounts and tub.
43. Lightweight steering wheel or steering tubular shaft.
44. Aluminum engine hub or balancer.
45. Remove windshield washer pump and plastic container.
46. Remove portable jack.
47. Remove parking brake handle and hardware/cable.
48. Lightweight fan.
49. Aluminum alternator and replace bracket.
50. Aluminum oil pan
51. Remove rear window struts
52. Belt drive
53. Remove passenger seat entirely (not for me)
54. If you are painting your car anyway paint it white.
55. Trim off any tabs and brackets off your frame as you remove stuff.
56. Remove all power window stuff, gut the doors inside if you dare.
57. Aluminum door skin if you have entirely gutted the doors.
58. There are tons of stuff you can do with your engine to reduce weight...
An example of engine weight reduction, Brodix makes a lightened version of their aluminum engine block that has been machined heavily to reduce weight...mainly found in sprint type cars but the concept works if you are wanting to cut weight. Eliminating a balancer and swapping on an aluminum hub has weight benefits but many question the long term effects on the engine, lightweight winberg crankshafts can get down to 27 to 30 lbs, titaniam connecting rods will save weight , with the right stroke and block clearance billet aluminum connecting rods can offer weight savings, heads...rarely do people select aluminum heads based on their weight compared to other aluminum heads however some are heavier than others. Sheet metal intake manifolds offer a weight reduction over cast aluminum intakes, titanium valves and retainers offers a savings, a 3 or 4 gallon fuel cell limits your weight and fuel weight.
The list can go on and on depending on if you are strictly drag racing or driving the car a little on the street. If you are going to street drive the car removing the power steering pump is probably not wise especially with bigger front tires.
NitrousSam
Most people bracket race as a means to have some fun since true class racing is pretty darned expensive. As such, weight reduction is an effective means of making your car quicker, meaning having more fun. Also, if getting competitive and running the super classes, all have minimum weights, and all are much lighter than any stock car.
Technically, you are right - that weight doesn't matter in true bracket racing. But, as most people are trying to have fun and make their car as quick as possible (while still being predictable), weight reduction is a part of bracket racing.
weight IS important in bracket racing to an extent. most bracket cars will remove and drill just about everything they can. less weight means faster times and less load on the motor and other parts as well. you can also acheive your ET goals with a less expensive, smaller motor. this is really why i'm trying to ascertain a target weight reduction # which is easy and fairly cheap to obtain.
i know about weight though... i bracket race in a pig heavy ~5,000 lb (w/driver) Lightning right now. stock block, it runs 8.0s in the 1/8th, not too shabby. the motor would be bad azz in a 3,000 lb car though! she's got about 700 passes on her so I am retiring her before something blows and it is not a dead consistent platform due to the supercharger and some of the electronic stuff the ECU does (adaptive strategy, timing retard for IAT2 temps after supercharged air, etc). i did well enough this year in the truck to make it to the IHRA div 1 Bracket Finals, from which i just returned. looking
NitrousSam
NitrousSam
This man won over 40 events in 2006 and none of his cars have any drill holes or anything removed... think about how many round wins that represents and that 99.9% of the cars he beat were faster than him...cut a light and run the number...if you're of the ilk that prefers to be the chaser then you do need a faster car for sure...best of luck...
personally i like to be the chaser, and tend to think there is a slight advantage for the faster car due to winning rounds when a slower car redlights (remember the FIRST to redlight is the loser). plus it's easier for me to judge where we're at at the line rather than looking over shoulder. i do hate waiting for seconds at the tree on slow cars like that. a lot of racers get anxious and go red. i raced in the ihra div 1 finals this year. most footbrake cars there were in the mid 6s to low 7s.
