1989 Factory HP Rating?
Old Nov 10, 2006 | 06:26 PM
LIVIN KC's Avatar
LIVIN KC
3rd Gear
Default 1989 Factory HP Rating?
The console plate on my 1989 reads 250 HP and 10.1 Compression.
Why do I not see this in any factory specs?
Old Nov 10, 2006 | 06:35 PM
*89x2*'s Avatar
*89x2*
From: ...tearing up the highways, one state at a time™®©
that was not correct, that is why.
Here are the accurate specs: http://www.corvetteactioncenter.com/...9/89specs.html
Old Nov 10, 2006 | 06:50 PM
LT4BUD's Avatar
LT4BUD
1989 was either 240 or 245......not 250
Old Nov 10, 2006 | 07:10 PM
LS6 Motor's Avatar
LS6 Motor
This is interesting, for my 1991 it shows 245, 250 HP depending on where in the production run it was. I don't see any differences in the mechanicals of the motor, so the only thing I can figure is that it must have been a different tune with the chip.
I also think it may have something to do with what gear ratio that is in the car, which leads me to believe it was the tune.
Old Nov 10, 2006 | 07:14 PM
*89x2*'s Avatar
*89x2*
it has to do w/ sport mufflers and gear ratios
Old Nov 10, 2006 | 07:39 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
My 1989 shows 245HP and 9.5:1 compression. It's a 6 speed w/3.54 gears.
Old Nov 10, 2006 | 07:52 PM
*89x2*'s Avatar
*89x2*
^^^ Sport mufflers
The 2.xx series geared cars, had one outlet on each muffler plugged shut to reduce (eliminate) drone
3.07 automatics and the stick shift cars had sport cans out back
Old Nov 10, 2006 | 10:17 PM
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
It has to do w/ sport mufflers and gear ratios.
The 2.xx series geared cars, had one outlet on each muffler plugged shut to reduce (eliminate) drone.
3.07 automatics and the stick shift cars had sport cans out back.
The gospel has spoken!
BTW, sport mufflers were restricted to coupes only.
Old Nov 11, 2006 | 04:55 PM
juanathandavid's Avatar
juanathandavid
Since we are discussing factory '89 specs, what does a healthy '89/4L60/3.07's run in the 1/4 mile? What about 0-60?
Old Nov 11, 2006 | 05:06 PM
CTYANK2's Avatar
CTYANK2
St. Jude 15 Year Donor
St. Jude Donor '07 thru '25
I think 0-60 stock was about 5.7 seconds and quarter mile around 13.8 ?
Old Nov 11, 2006 | 05:18 PM
juanathandavid
wow. i love my 89.
Old Nov 11, 2006 | 05:35 PM
Wheelman's Avatar
Wheelman
The correct term for the transmission in your '89 is a 700r4. Even though they are basically the same thing if the 4L60 doesn't have the "E" designation, I don't believe they started calling them the 4L60 until around 1992.
Old Nov 14, 2006 | 06:55 PM
LIVIN KC's Avatar
LIVIN KC
3rd Gear
Default Guess the factory plate is wrong . .
Thanks for the replies. I have studied the 89 engine specs very carefully and do not understand why my console plate reads as it does.
I have yet to find another 89 in my area with the same plate.
Curiosity just has me . . sorry.
Old Nov 14, 2006 | 07:58 PM
LT4BUD's Avatar
LT4BUD
The console plate is not factory....it is aftermarket so it could say anything......
the L98 engine did become available as a 250hp engine, but not in 1989, so someone installed an incorrect aftermarket console plate..
Old Nov 14, 2006 | 09:13 PM
*89x2*'s Avatar
*89x2*
certainly NOT a factory item.
Old Nov 14, 2006 | 09:27 PM
cplonner's Avatar
cplonner
Are the gear ratios on that site right? i have heard from many different people different information.
Old Nov 14, 2006 | 10:01 PM
vader86's Avatar
vader86
There were 2 different rear axles offered in '89. 3.54 was the early set. 3.33 came next.
The 2nd gear ratio for the 700 does not match anything I have, and the 3rd gear ratio for the M6 doesnt either. Unless these have been altered from year to year...which is not unlikely.
To 1989 Factory HP Rating?
Old Nov 14, 2006 | 11:18 PM
Z-07 freak's Avatar
Z-07 freak
All rear axle ratios for the `89 model year.
2.59 base auto coupes & verts
2.73 performance axle auto verts
3.07 performance axle auto coupes
3.33 most 6-sp manual coupes & verts
3.54 early 6-sp manual coupes & verts, and the ZR-1 prototypes
Old Nov 15, 2006 | 05:47 AM
*89x2*'s Avatar
*89x2*
Yes, and more: http://www.corvetteactioncenter.com/...89/89prod.html
Old Nov 15, 2006 | 08:24 AM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
Same here.
I need to figure out how to remove it since none of it is correct anymore heh, or figure out how to etch "stock specs" into the plate LOL.
