Correct A Cap?
Old Nov 10, 2006 | 07:19 PM
Steel Breeze's Avatar
Steel Breeze
Default Correct A Cap?
Anybody know if they make a Crossfire, or Correct A Cap for the big HEI?
Old Nov 10, 2006 | 09:27 PM
Steel Breeze
Speak to me, oh knowledgeable one's. It's the distributor cap that has the spark plug sockets, that line up on each side of the engine. Passengers side: 2 4 6 8 Drivers side: 1 3 5 7. Makes for a nice neat plug wire arrangment, and a more tighty engine bay.
Old Nov 11, 2006 | 06:50 PM
Steel Breeze
Ummmmmmm...:o
Old Nov 11, 2006 | 07:18 PM
Idburnu's Avatar
Idburnu
My 84 has a Crossfire Cap on it, I purchased it from Jegs a good number of years ago. It definitely cleans up the wire routing and I never had any problem with it. Not sure if they still make it or not since it was probably 6 or 7 years ago when I bought it.
Edit: Found a link to it, seems to be the only place left that has them, not sure if this is the model you need, but here it is:
http://www.yearwood.com/store/produc...&s=&id=CRO4512
Old Nov 12, 2006 | 12:07 PM
Steel Breeze
Hey that is what I am looking for. However mine is a screw down cap. Athough I think it has provisions for the L type... Many Thanks...
Old Nov 12, 2006 | 12:50 PM
bogus's Avatar
bogus
that would look cleaner, wouldn't it?
Old Nov 12, 2006 | 02:07 PM
CFI-EFI's Avatar
CFI-EFI
I fail to see the logic of paying $50.00 for a rebuilt $20.00 cap. Plus, once you have the plug wires set up for the 180° cap, you're stuck buying, used, $50.00 caps. There is no question it is neater, but at what cost? I guess it is up to the individual as to whether it is worth it it not, for the risk of a rebuilt cap at the more than double price.
RACE ON!!!
Old Nov 12, 2006 | 02:45 PM
Steel Breeze
RACE ON!!!
You have to build custom plug wires as well. I have a brand new set of stock wires. I'm not sure what I will do. I may just get all the stock wire seperators, as mine are old, an shatter. Then put them on the way the factory had them. They have done a pretty good job of keeping them neat. Then I could buy regular caps, in which I have a brand new one of those to. I'll check it out when I get to that point. Those packard seperators are a little expensive...
Old Nov 12, 2006 | 03:37 PM
Idburnu's Avatar
Idburnu
It looks a lot neater and I had no performance issues with it. I had the MSD HEI ignition module and MSD coil in it and it would definitely provide spark through more RPM's than the car would turn, lol. It is a small price for someone who is concerned about aesthetics. I wouldn't recommend it for the keep it stock crowd, or those who get worked up over a few bucks for no tangible performance gain, but if a priority for you is how your engine looks it is great.
Old Nov 12, 2006 | 08:45 PM
CFI-EFI's Avatar
CFI-EFI
Maybe, maybe not. But the point is to clean up the engine compartment, right? What is the point, if you don't shorten the #3 wire (and others) that runs all the way from the right rear of the cap, around the front of the cap and past the point it connects on the new cap? Then if you DO shorten it, how do you swap back to a reasonably priced cap? "Those packard seperators are a little expensive... " Those separators are chicken feed compared to that cap and while the separators don't last forever, they aren't a maintenance item like the cap is.
A "few bucks'? A premium of 250%, or more, is a "few bucks"? If your car cost 2 1/2 times what you paid for it, would you have bought it?
RACE ON!!!
Old Nov 12, 2006 | 08:49 PM
clevette's Avatar
clevette
I think Accel makes it. I saw it in a Jegs catalog. I think it cost about 50.00.
Old Nov 12, 2006 | 10:24 PM
Idburnu's Avatar
Idburnu
We could do abstract comparisons like that all day long on a myriad of topics, but my point remains valid. A DECENT regular cap might run you 20.00 and this one runs 50.00. A difference of 30.00 is in todays world a "few bucks". If you balk at 30.00 to get something that is arguably a visual upgrade at best, thats fine, but in a hobby that can cost thousands and thousands for changes that some don't see as necessary or an improvement, that remains a drop in the bucket.
And no, I wouldn't have paid 2.5 times more for my car, but after the pleasure of owning it, I probably wouldn't let it go for less.
To Correct A Cap?
