4L60E Question
Old Nov 11, 2006 | 12:57 AM
Berserker78's Avatar
Berserker78
Default 4L60E Question
I picked up a 4L60E that I would like to put into my 78 because I was told that it could be set up for manual shifting and not need a computer.
Does anyone know how to set this up? I have seen references to it being done, but not the process. If it is not possible, is anyone interested in a rebuilt 4L60E?
Old Nov 11, 2006 | 02:27 AM
kopbet89c4's Avatar
kopbet89c4
I think you are talking about the 700-R4 or the 4L60. The 4L60E needs a computer to know when to shift.
Old Nov 11, 2006 | 02:52 AM
LS6 Motor's Avatar
LS6 Motor
as the E in 4L60E depicts.
Old Nov 11, 2006 | 05:14 AM
VenkmanP's Avatar
VenkmanP
I'm pretty sure I've seen "full manual, no computer" versions of 4L60Es offered by rebuilders.
Wait to hear from PeteK - he's the resident 4L60E expert.
Old Nov 11, 2006 | 08:27 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Actually it's a mechanically simpler trans that it's predecessors.
Old Nov 11, 2006 | 11:21 AM
Pete K's Avatar
Pete K
Because the 4l60e does not contain alot of the parts that the 4l60 does. I cannot imagine how they could be converted to a non electronic version for a cost effective amount of money. I honestly do not know though. They do sell stand alone computors that can run them in just about any vehicle.
Other than the ability to change shift points precisely at a given mph, I don't think there is an advantage to using them in a non pcm car. The main parts of the trans are identical to the 700/4l60. Slight improvements were made over the years, but most parts and pieces are identical.
Old Nov 11, 2006 | 02:02 PM
Berserker78
I ran across a transgo kit that seems to be what I am looking for based on the description, but I don't know enough about it.
http://www.bulkpart.com/Merchant2/me...roduct_Count=2
Performance stick shift kit, TransGo 4L60E-3, Stick Shift: Full manual control Converts back to automatic. Competition, off road and pro-street. Holds 1st, 2nd and 3rd to any RPM; Backshifts to 3rd, 2nd and 1st at any RPM.
For transplant or use with no enectrical: Includes 46-MOD (Vacuum controlled line pressure)
Emphasis mine
Old Nov 11, 2006 | 03:28 PM
VenkmanP's Avatar
VenkmanP
Emphasis mine
I was thinking I'd seen a shift kit that does what you want, but last night I could only find the "full manual" description in 4L80E kits.
I think that's what you need.
I'd go look around on street rod forums for 4L60E information. That would be the primary market for such a conversion.
Old Nov 12, 2006 | 01:56 PM
Pete K's Avatar
Pete K
If I may offer an opinion, sell the 4l60e and pick up an aux valve body 87 1/2-92 4l60. In my opinion, this will be a better solution to your goal, and give minimal heartburn with great results.
Again, just an opinion. If you do convert the electronic unit, please do a wrie up. I am interested. ...Pete
Old Nov 12, 2006 | 01:59 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
The next person to respond with non related answer will be banned.The next person to respond with a non related answer will be banned.
To 4L60E Question
