Wheel Q - 18x9.5 +50 Offset
Old Nov 12, 2006 | 12:29 AM
AZ_Matt's Avatar
AZ_Matt
Default Wheel Q - 18x9.5 +50 Offset
Guys,
Just wanted to run something past the collective knowledge here...
I found a great deal on some SSR GT2-H wheels that are 18x9.5 +50mm offset. Good looking wheel, light weight (19.4 lbs), and TireRack.com has them listed at $129 each!
Here's the question - TireRack has them listed for C5s, but not C4s. C4 OEM 17x9.5 have +56mm offset, so +50mm should place the edge of the wheels outboard by roughly 1/4", right? That wouldn't pose a problem with 275/35-18 tires, would it? Anyone have these wheels? Anything I'm missing - maybe brake clearance issues - but wouldn't the lesser offset help? Just trying to figure out why TireRack has them listed for the C5s but not C4s...
If you want to see them, just load up a C5 in the wheel shopper. They also have the same wheel in +55mm offset for $249.
Thanks!
Matthew
Old Nov 13, 2006 | 01:58 PM
TM-Z06's Avatar
TM-Z06
These will work on 89-96 C4's with no problem. Tire Rack stays with factory offsets in it's offering. While a certain wheel/tire combo might fit, because the size and offset is not the same as OEM, it will not be offered.
Old Nov 13, 2006 | 05:19 PM
pr0zac's Avatar
pr0zac
i have a gm c5 rims on my 96 and 275's all the way around.. no problems whats so ever..
Old Jan 5, 2007 | 02:36 PM
jpandes's Avatar
jpandes
I just bought some of these 18's & 19's for my C5 Z06. Once I get tires on them and on the car. I'll post some pics for ya. You can't beat the price.
Old Jan 14, 2007 | 08:44 PM
Steve Theodore's Avatar
Steve Theodore
jpandes,
Which offset did you go with, and how does it fit relative to stock wheels? Thanks!
Old Jan 14, 2007 | 09:20 PM
jpandes's Avatar
jpandes
Originally Posted by Steve Theodore
jpandes,
I have the 18 x 9.5" +50mm offsets up front and 19 x 10.5" +62mm in the rear
I think the fronts stick out a little bit more than the rears. They look fine, but I think the +55mm offset would be just right. I plan on trying out some 5mm spacers on the rears.
I'd post some pics but my digicam just broke.
John
To Wheel Q - 18x9.5 +50 Offset
