94 6 speed shifter question
Nov 13, 2006 | 06:17 PM
i want to change the shifter **** on my 6 speed. before i do something stupid, how does the old one come off??
thanks
vc
Nov 13, 2006 | 06:25 PM
Quote:
thanks
vc
First, pop the gear pattern cover off of the shifter. I used a small flat head screwdriver. Next, remove the dowel pin (I guess that is what it is called). It pulls straight up. I used a pair of pliars. Next, the **** will simply screw off. The dowel pin keeps the **** from spining.
Nov 13, 2006 | 06:41 PM
St. Jude Donor '12
There's a tech tip on this. Good place to check first
Nov 13, 2006 | 07:21 PM
It Spins off, It Is threaded on just like any other shift ****, I forgot I have the hurst ****er installed and it does not use the retaining clip.
Nov 13, 2006 | 07:34 PM
ACTUALLY MOJAVE IS EXACTLY RIGHT. I JUST WENT DOWN AND CHANGED MINE. THANKS
MOJAVE
IF YOU GUYS ARE INTERESTED THE C6 **** LOOKS AWESOME IN THERE.
VC
Nov 13, 2006 | 08:57 PM
St. Jude Donor '12
Isn't reverse labeled wrong?
Nov 13, 2006 | 09:07 PM
Quote:
YEA, BUT IT DOESN'T BOTHER ME. LOOKS REALLY GOOD
Nov 14, 2006 | 12:03 AM
Security feature. Always park head-in.
