where are the grounds for the engine?
Old Nov 14, 2006 | 03:31 PM
cplonner's Avatar
cplonner
Default where are the grounds for the engine?
I have been having my plug wires arc through the insulation lately. I was told today this could be due to bad grounds. I can see the ground for the battery on the back of the block. Where does the block ground to the frame? Would there be any other grounds on the engine that could create this other than the frame ground and the battery ground?
Its a 1986 corvette.
Old Nov 14, 2006 | 06:29 PM
IRAraid's Avatar
IRAraid
Default Plug arc
Plug wires arc due to bad plug wires. Replace them first.
Cap and rotor too.
Old Nov 14, 2006 | 06:41 PM
cplonner's Avatar
cplonner
replaced them and everything is perfect!
Old Nov 14, 2006 | 09:07 PM
silver86's Avatar
silver86
Sweet! Kinda figured it was something simple like that. Time to call these professional Corvette mechanics that overcharge and fix nothing! Glad I didn't reach out and touch that wire Sunday....might have been a shocking experience
Old Nov 15, 2006 | 03:24 PM
cplonner's Avatar
cplonner
car has no spark today, how about those grounds? Looked at the wiring havent found anything so far, going to keep looking.
What grounds could effect this?
Old Nov 15, 2006 | 06:19 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I doubt that this is a ground issue but anything's possible. That being said, when in doubt, ground. No problem has ever been caused by an excess of grounds! I once bought a very old Dodge pick-up that had been owned by a friend's dad. He was a mechanic and drove that truck for years until he died. I never saw so many grounds on one vehicle, he'd put them everywhere! And I thought that I tended to overkill things. You know what though? I drove that old beast a good number of years myself and never had much trouble out of it. I even made two round trips to Ohio in it with no issues, and the truck was about 30 years old by then. Nothing like buying a vehicle owned by a fellow old hard-headed mechanic.
Old Nov 15, 2006 | 06:26 PM
CFI-EFI's Avatar
CFI-EFI
When the wires were arcing. where did the spark go? The engine? That is the same ground the spark plugs use. Are the wires actually acing? Or are you seeing the corina glow that is natural and acceptable?
RACE ON!!!
Old Nov 15, 2006 | 06:36 PM
cplonner's Avatar
cplonner
ok I figured out it has no spark becauser the ignition wire is bad, when I bend and move it the engine will die or when the voltmeter reads on the batt. connection coming from the dist less than 7 volts, it needs at least 7 says my manual (haynes). Gotta do some wireing tommorwo
Old Nov 15, 2006 | 06:47 PM
CFI-EFI's Avatar
CFI-EFI
Since you have no spark, what is arcing?
RACE ON!!!
Old Nov 16, 2006 | 08:05 AM
jordis's Avatar
jordis
boo ... just kidding
Old Nov 16, 2006 | 08:40 AM
WildWilly55's Avatar
WildWilly55
Back to the orginal question. I also have an 86 and was not getting a very good ground to engine from installing my stereo. Found on the Driver side of motor the ground strap had not been reconnected from engine rebuild that spring.
Old Nov 16, 2006 | 10:38 PM
johnnyevans's Avatar
johnnyevans
There are several grounds in that location. In older years, that was where the pivot ball for the bellcrank was. Make sure those are tight, seems like there were 4 ground wires on the last one I pulled.
Old Nov 16, 2006 | 10:54 PM
cplonner's Avatar
cplonner
RACE ON!!!
The arcing problem is already taken care of, now it will not start.
The arcing was fixed by replacing the plug wires.
Old Nov 16, 2006 | 11:22 PM
mothersworry's Avatar
mothersworry
The main ground from the battery to the block has a small groud wire that goes to the frame right behind the frame support bar that runs across the battery area. Is this what you are looking for?
Old Nov 18, 2006 | 08:15 AM
cplonner's Avatar
cplonner
Yes, thank you.
Old Nov 18, 2006 | 08:54 AM
VetteUSA's Avatar
VetteUSA
St. Jude Donor '07
Even though it looks like you got the answer you were looking for, here's a picture of all the ground locations.
To where are the grounds for the engine?
