Roller conversion to non-roller block....
Old Nov 14, 2006 | 05:01 PM
CorvAdel's Avatar
CorvAdel
Default Roller conversion to non-roller block....
Is it possible to use factory GM 87-up roller lifters, lifter retainers,pushrods, and spider tray in a 85/86 block if the bolt holes are drilled and tapped for the spider tray...? TIA
Old Nov 14, 2006 | 05:07 PM
Pete K's Avatar
Pete K
Nope.
Lifter bosses are too short and the standoffs are raised in the lifter valley on an 87 and up block. Then you have the thrust plate issue, but that is easily solved with a thrust button.
In your case, a retro fit roller conversion is the best option.
Old Nov 14, 2006 | 05:40 PM
CorvAdel's Avatar
CorvAdel
Thanks Pete for the good info...
The next question then...is it worth the effort and what are the expenses to retro-fit..?
87 vettes made only 5hp more than 86's...
Old Nov 14, 2006 | 06:13 PM
Pete K's Avatar
Pete K
The advantage in power does not really come from the roller lifter, but the ability for the roller style cams to have more agressive lobes. This is what makes the power worthwhile. The wheel on a factory roller lifter, in my opinion does not give any gain at all due to the larger, heavier valve lifter. Oil temps probably go down a bit from the roller though.
In my opinion, if you are building a motor to run hard, retro roller is worth every penny.
Old Nov 14, 2006 | 06:53 PM
CFI-EFI's Avatar
CFI-EFI
Nope.
But it is possible to use 60°, V6, factory lifters, to save money over the cost of the retro roller lifters. If you have further interest, contact Lionsden.
RACE ON!!!
Old Nov 14, 2006 | 07:53 PM
CorvAdel's Avatar
CorvAdel
Originally Posted by CFI-EFI
Nope.
RACE ON!!!
Thanks CFI...yes, I do have further interest and I Googled Lionsden..Are you referring to the Crossfire Forum? If so, I can't seem to access it with my computer.
Is Lionsden a business, a private individual a forum...?
How can I contact it/them..?
TIA
To Roller conversion to non-roller block....
