I was going to post this with the thread on the "Cut Lids", but this isn't really about a cut lid and that topic is about killing me.
But anyway here's my thought and question about an alternative cold air set-up.
I have an SLP Claw, or triple threat, or whatever you want to call the thing with three K&N filters on the end of it.
What I have been thinking about doing for some time now is to cut a hole in the shroud below the filters, and then build a fiberglass box around the filters and air duct. I would use some foam sealing material around the metal duct of the Claw to keep debris out of the engine compartment. I also have a BMAD front air dam, and think this would help bring cooler air into this area at speeds over 35 or 40 mph. Any thoughts about this set up?
No opinions
You guys usually have all kinds of opinions!
I have the triple claw and...
1) It looks great.....
2) It ends up sucking in hot air from the engine compartment since the factory seals that block hot air are no longer effective with the claw.
3) The size of the claw filter cross section and tubing is effectively identical the the OEM setup, so especially if you have a modded engine you really have not improved things a whole lot...
So I think your idea is a good one......you will be getting cool outside air, much like the rammer setup.....not sure about rain performance?.....at least a moderate ram air effect
I think a little insulation around the tubing would help keep the incoming air cool..
I am thinking about doing something perhaps similiar, would like to use larger filters, but space is a premium...
Good luck....keep us posted on what you do...I know I am interested
it sounds like you are making a homemade "bpp vortex ramair" box out of your claw... which many members have stated in the past doesn't do much for them.
cutting the shroud sounds like a cool idea to get that front air coming in, i don't know if making a box would be worth your time though.
Also keep in mind whatever you make may block air that is needed for the radiator below that shroud and may effect cooling.
I am learning as time goes on and reading a lot of this stuff that every single piece of the C4's ,even though we think a lot of it is a bad design, seems to have a purpose that fits tightly into the C4 total puzzle, and anything we do to them may decrease the performance of some other piece of the puzzle.
TIA
Don Haller
Severn, MD
You've got the right idea... I did something similar with Legion's '96, except didn't box in the filters. He had a Rammer on it already, (which warped per norm and I swapped it out for a Claw), and I modified the hole to better work with it.
I'm doing the same thing with my '92, and couple with the BMAD I have on it, I should be able to tell if it's a worthwhile project.
I also have the "claw". I ran well without it and also well with it. I think we get plenty of air and run very cool (177-179) on the highway at 70mph and 190-197 in heavy traffic in South Florida...
Are you looking to get more air in or to cool down your engine?
Cooler air into the air filter elements.
My car runs cool enough with the BMAD. I don't see how you run 177-179 in Florida unless you have some mods to do that. Tell me more. Aftermarket radiator? I can run my fans all day and still run around 210 to 220 which in my book is just right.
Yes, I monitored my IAT with the claw and once everything is warmed up, the intake air temp starts to climb.......if I remember right the day I did it the IAT was about 20 degrees above outside air temp.....really climbed fast when you would stop at light, then a little cooler when moving....so the 20 degrees is not precise, but enough to make me look harder and the answer is easy when you look...it is sucking in hot air from the engine compartment.....so your box idea to block out engine air sounds like a good solution to me...
I did something similar with the stock set up. I "rigged" it first to see if there would be any difference. I cut the shroud and cut the bottom of the filter housing to flip the filter so it faces down into the radiator cavity. When first done I could feel a little quicker response. This is with a stock filter, so I'm sure if it was a K & N and done better it would make more of a difference. I would like to get a new shroud and start over with the SLP filter lid that is seen in the link. It always seems like something comes up that doesn't allow me to spend extra money though so I still have gotten to it. It has been "rigged" for like 2 years. So as can be seen it has been a pretty long time and I haven't had any problems with it being open, especially water. No problems in heavy down pours. I just make sure I avoid puddles. I would say if you can come up with a way you like, go for it.
To get it to run cool down here I make some changes:
1. Removed and cleaned the radiator
2. Replaced both upper and lower radiator hoses
3. Installed a Big Mouth Air Dam
4. New radiator cap
5. New 160 degree thermostat
6. Entire coolant flush and replace with 50/50 Dexcool & distilled
7. Mobil 1 5W30 oil
I'm sure I'm foregetting something. Thats about it. ( T/B bypass)
I cut my shroud a few months back to work with the claw. A little more dust on the engine is the only down side. I'm trying to design a box for it now as a winter project.
4. New radiator cap
7. Mobil 1 5W30 oil
The only thing different than mine is the 160 degree stat. I might have to try that. I cleaned my radiator during the summer and that seemed to work good for a few months, but I guess I getting more debris in there with the BMAD. I still think that 210-220 is fine operating temps for these cars.
Now I got to make some plans for that box! I'm thinking about fiberglass matt and resin over top of a mold in the desired shape.
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
What do you guys think of the sealed cold-air intakes that are scoop/ramair type systems vs the ones without scoops?
The scoop puts the intake directly in the path of air flow. It also makes for more restriction if the car isn't moving.
No scoop means the intake is always susceptible to pulling air over the surface of the radiator. I also suspect that the pressure will be less than one with a scoop.
Here is my post on the subject from a while back. Haven't made any more progress on it as of yet.
You guys have already seen my dyno test of the claw vs. stock and unfortunately we didn't see much in the way of a HP gain. Here is phase two of the project: ducting cool air from under the front bumper. The SLP unit lends itself to this quite well as you can see by the photos. I built the scoop out of aluminum, not too tough just a lot of measuring and cutting. I will be adding more to it in the near future, definetly something up top to shroud the air intake area and possibly more of a direct scoop down below. I don't expect any dyno gains from this but it should help in real world driving by providing a constant stream of ambient temperature air to the filters.
I agree with you...we sometimes try to do better then a company that spent millions of dollars in research. I prefer to leave mine stock. I've seen many peope in the sport bike world try to tweak a bike that has 180 hp and will do 176 mph, to go even faster. Why?
