intercooler location
Old Nov 15, 2006 | 04:02 AM
alx's Avatar
alx
Default intercooler location
Hello.What do you think about procharger intercooler location in C4 ?It looks abnormal.
I dont understand how airflow is going through the intercooler?May be somebody has another location of intercooler on C4 ?
Old Nov 15, 2006 | 06:58 AM
bacardioil's Avatar
bacardioil
Yes, use Blower works Alki and water injection system. Thats what I use and never had a problem.
Regards
Old Nov 15, 2006 | 08:16 AM
LTxDave's Avatar
LTxDave
It works because the entry is in a high pressure area as the car is moving. Air hits the dam below the radiator/intercooler entry and is forced up into that cavity. It has to go across the radiator and intercooler. The Procharger unit is limited in flow capacity, but it does work when the car is moving.
Old Nov 15, 2006 | 08:36 AM
alx's Avatar
alx
What do you think if i ll put fan on it?
Old Nov 15, 2006 | 01:59 PM
drochau's Avatar
drochau
The TT APS G35 kit uses two Puller fans on the intercooler. It works pretty darn well at idle, though you need to have a switch to shut them off above 50 mph as the air flows faster than the fans can pull it through.
Old Nov 18, 2006 | 01:37 PM
lisoundsvette's Avatar
lisoundsvette
i used the blowerworks intercooling kit also. gregs kitis very well thought out. not to difficult to install. and worked well for me
http://forums.corvetteforum.com/show....php?t=1546454
Old Nov 18, 2006 | 02:12 PM
qwiketz's Avatar
qwiketz
I was thinking of where I could mount an air to water unit all week and came to the conclusion that there just isn't room for one on my car with all the coolers and the ac unit. I was thinking of using a spearco 2-2031 which measures roughly 16/16/4.5".
Old Nov 18, 2006 | 02:37 PM
Mo_Bandy's Avatar
Mo_Bandy
Russ,
Greg, has a bladder that lays where the original air filter would mount, It holds like 2.5 gallons... Works great too!
Alx, I'm not sure if Procharger mentions but you would want to cut a hole in the shroud below the intercooler. If you are considering buying one... I've been there done that... the gaseous injection in is much better.. ~my personal opinion~
Mo
Old Nov 18, 2006 | 02:53 PM
qwiketz's Avatar
qwiketz
yeah, I'm fairly convinced that with the cfm that this blower is going to be pushing, there's not any way to get an air to air intercooler to work with all the accessories and coolers I have on the car. There just isn't room. I was thinking of an air to water intercooler, but it doesn't look like there's space for that either. It looks like alky injection is going to be the only thing on my car for now.
To intercooler location
