problem with new mini starter
Old Nov 15, 2006 | 05:28 AM
purplevette84's Avatar
purplevette84
5th Gear
Default problem with new mini starter
hey guys ,
i just switched to a mini starter .when i crank the veh it sounds fine but as soon as the engine starts i hear it grind .i would assume the when this happens the engine rpm has exceded the starter rpm ans should alow the starter to retract but ???? i played with shims ( 1 shimto no shim )and it didnt help ...any info you guys may have would be great
Old Nov 15, 2006 | 02:10 PM
Square's Avatar
Square
When I installed my ministarter, I also played with the shims as it didn't sound right. I had a shop shim it for me while they had it for other work, and I was told that they had to "shim one side", as in, only put a shim under one bolt to angle the starter to get it to line up correctly. It is better now, but every now and then it will still grind when I first turn the key.
Old Nov 15, 2006 | 04:42 PM
USAsOnlyWay's Avatar
USAsOnlyWay
Hmm, my only guess is that it needs to be shimmed off the block a bit if it is locking in the flywheel. You should be able to see what is going on through the dustcover. Make sure you only do this if you are in a pit or something and have proper eye protection. I wouldn't suggest it necessarily, but I did it to verify everything looked good in motion when I did mine...
Old Nov 15, 2006 | 06:03 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
I have two mini starters, one for my original 350 and a new one for my 383. Both of them have holes bigger than the bolt and all the starter bolts I looked at had the knurling in the wrong place. The guy I bought my second starter from gave me a pair of stainless steel sleeves that fit over the bolt and fits snug in the starter. I have no idea where you might get these but maybe if you check with some of the starter companies they could supply you with them. Maybe even a hardware store may have something that would work, they look just like a big roll pin, they are split lengthwise so they conform better. I'm not sure if this would cure your problems but it sure can't hurt to have the starter perfectly square to the engine.
Old Nov 15, 2006 | 06:07 PM
Bad Karma's Avatar
Bad Karma
You can pick those up at a hardware store in the bolt isle.
To problem with new mini starter
