ride height
Old Nov 15, 2006 | 12:10 PM
byedan's Avatar
byedan
Default ride height
on my 94 it sits about a inch lower in the rear than stock corvettes is this hurting my handling and if so how hard is it to repairs also the rear leaf spring is not broke
Old Nov 15, 2006 | 01:42 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
If you have to ask if it's hurting your handling, then it isn't.
You can raise the rear, if it bothers you, via the long bolts that connect the ends of the rear spring to the hub carriers...easy to see what I'm talking about once you get your head under there....
Larry
code5coupe
Old Nov 15, 2006 | 09:52 PM
Hotred94's Avatar
Hotred94
As long as your front sits lower than your rear then you are fine.
Old Nov 16, 2006 | 02:47 PM
byedan's Avatar
byedan
i thank they sit at the same level front to rear i need to check with a tape though
To ride height
