Scorp508 - question
Old Sep 22, 2001 | 03:38 PM
Fla96LT4's Avatar
Fla96LT4
Default Scorp508 - question
What was the $14 kit for the exhaust air pipe after you cut it ? Rubber hose and clamps or ?
Old Sep 22, 2001 | 06:10 PM
Rich B.'s Avatar
Rich B.
Default Re: Scorp508 - question (Fla87)
(I was gonna reply to the original Q, but had to go into work!)
I used a brass tubing connector - the kind with compression fittings (union?). The tube on my '86 is 1/2"; so I just cut it with a tubing cutter, installed this brass connector thingy on each end. Now the tube is quick detachable, and rust resistant.
Old Sep 22, 2001 | 06:16 PM
Fla96LT4's Avatar
Fla96LT4
Default Re: Scorp508 - question (Rich B.)
Great idea........ and a great solution to the problem. Thanks for the reply. Home Depot here I come! :D
To Scorp508 - question
