GM Rear End Additive part #??
Old Nov 16, 2006 | 02:42 PM
dc3plt's Avatar
dc3plt
Default GM Rear End Additive part #??
I have the 1995 Dana 36.
Does anyone have the GM part # so I can get the correct additive?
Old Nov 16, 2006 | 03:10 PM
Jaxian's Avatar
Jaxian
Default additive
This is from a bottle I had hanging around from years ago, so I dont know if the number has been superceeded but here it is. I have a 87 with a Dana 44 but the guy at the chevy dealer said the same number came up for all C4 corvettes.
GM
Goodwrench
Limited Slip Differential
Lubricant Additive
1052358
4 fl oz
Old Nov 16, 2006 | 03:14 PM
C4boy's Avatar
C4boy
If you're going through the dealer, they'll know exactly what the limited slip additive is. I'm pretty sure it's all the same. GM part # is 1052358
Old Nov 16, 2006 | 03:30 PM
_twisted_'s Avatar
_twisted_
last time I bought through dealer it was 8oz bottles - like said ask for limited slip additive at any gm parts counter.
if you say rear end additive you might end up with preperation h in the tube
Old Nov 16, 2006 | 04:38 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Unless your at a dealer in SanFrancisco
Old Nov 16, 2006 | 06:41 PM
VenkmanP's Avatar
VenkmanP
It is the same for all GM cars, but some dealers are clueless. When I needed some a couple years ago, I went to the nearest dealer and asked for LS additive, and he said he needed a part number. Couldn't/wouldn't even look it up by make/model.
Next time I was out, with the part #, stopped at another dealer, and as soon as the words "limited slip" were out of my mouth he headed around back to get some. He said he didn't need a part # because there is only one LS additive.
I don't go back to the first dealer...
p.s. Use two bottles.
Old Nov 16, 2006 | 09:01 PM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
Guys... just go to NAPA. TransX or some company makes the same stuff - it even has the GM spec right on the bottle. It also comes in a 10 or 12 oz bottle (IIRC) and is MUCH cheaper than the same stuff at the dealership
To GM Rear End Additive part #??
