Bad sputter at a standstill
Old Nov 16, 2006 | 11:59 PM
sempermarine29's Avatar
sempermarine29
Default Bad sputter at a standstill
I have a new long block LT1 rated engine with my automatic 4L60E tranny that was just 100% rebuilt. I had a new waterpump installed, new OptiSpark, New plugs and plug wires, new starter, new Radiator about 3 or 4,000 miles ago. The entire coolant system was flushed through the heater core. I had a new fule filter put in.
This is on a 1995 Corvette auto tranny. The engine has about 370 miles on it now. I stopped at the gas station to run in and buy something, about 3 minutes later I came out to start the car. It started ok but when at idle it ran like I was out of gas. Idle speed was about 2-300 RPMs. Let alone putting the car in Reverse or Drive. Once I get going though, you could swear I had just installed a new engine that was fine tuned.
I checked the plug wires and they all seem to be plugged in well, checked all of the vacuum lines and they are all new.
What is going on here???
Old Nov 17, 2006 | 12:01 AM
Pete K's Avatar
Pete K
Put a fuel pressure guage on it. Pump may be taking a dump.
Old Nov 17, 2006 | 12:03 AM
Pete K's Avatar
Pete K
If you just pumped the gas in it, you may have purchased a watery batch of gas.
Old Nov 17, 2006 | 12:06 AM
sempermarine29
I have been running on the same tank of gas and I am down to just above 1/4 of a tank and it ran fine all the way up until tonight. It actually ran like a champ this whole time. I don't see that if the pump is going bad, wouldn't that affect my performance while stepping on the gas?
Old Nov 17, 2006 | 12:17 AM
Pete K's Avatar
Pete K
Good point. It has been a long day and I was thinking backwards.
Old Nov 17, 2006 | 10:40 AM
mikey whipreck's Avatar
mikey whipreck
Do a search for problems fellow vette owners have once their tank drops below 1/2.
To Bad sputter at a standstill
