Nitrous questions
Old Nov 17, 2006 | 04:13 PM
Jcrow's Avatar
Jcrow
Default Nitrous questions
1. If the bottle is mounted in the back hatch area will the roof still fit?
2. It gets pretty hot in the car in the sun, will this cause any problems with the bottle getting too warm?
3. Is a purge really necessary?
Old Nov 17, 2006 | 04:26 PM
RacerX70CC's Avatar
RacerX70CC
1) no (unless the bottle's not in place)
2) yes (keeping the shade pulled helps a lot, as does tinted glass)
3) yes (for the best hit and "intimidation/showoff factor")
Old Nov 23, 2006 | 08:48 PM
NitrousSam's Avatar
NitrousSam
Default Nitrous
1. It will fit easily and you can actually mount an oversized 15 lb bottle and it will still fit.
2. Make sure your Nitrous bottle blowoff valve is vented outside the car just in case.
3. It really depends on how much nitrous jetting you are running. The reason I say this is because if you are running a 150 kit or larger without a purge you will go rich instantly creating an bog until the nitrous actually hits the engine. If you are looking to get the most out of your setup it is money very will spent.
NitrousSam
Old Nov 26, 2006 | 08:28 PM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
NitrousSam
Except I personally feel like running rich without a purge and bogging is the least of the worries. With any TPI plate or pre-throttle body wet kit a purge kit can also save a BIG BOOM. When spraying without purging the improperly atomized raw fuel without nitrous you'll be spraying while the air clears out of the nitrous line until the nitrious hits can puddle in the plenum. Now, what happens when a spark occures while a valve is open and a puddle of raw gas is near by?? Use your imagination! It aint purty! The fuel is far less likely to puddle when evenly matched with N20. I think a purge is a safety neccesity with pre throttle body TPI and plate wet kits. Obviously its not at all an issue with a dry kit.
To Nitrous questions
