hi there all,
hope all is well with you all!
i read in the tpis insider hints book that cutting back the centre electrode shield can help produce 10 horse power and 1 mph in top speed! is this true?
does it really help do you think?
when i looked at the spark plug ,the electrode does shield part of the spark plug there fore could restrict some of the flame?
any way thanks for reading guys!
glen
sxyvet
Australia
You only cut back to half way across the electrode. So you got half to set the gap with.
I noticed a small improvement in perf. But I was fouling plugs & it really helped not foul the plugs.
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
It shortens the effective life of your plugs and is way more trouble than it's worth. Unless you're a class racer going for every last fraction of HP, put your efforts elsewhere. You'll certainly never feel the difference. Standard indexing is more effective and I also consider it a waste of time with modern ignition systems.
I did it on a set of Autolite plugs a while back. Didn't notice any SOTP difference but didn't index them either. Can't speak to the life of the plugs since I changed them back to Rapid Fire # 5s the next summer.
not worth the effort. I thought AC Delco or some other plug manufacture was selling them now. From what I've read what little performance gain noticed is in RPM ranges we don't typically go to in DDs.
If it is hard enough to do and takes long enough, you'll swear you can feel the difference. S.O.T.P. However, I defy anyone to document a difference.
A few years ago I did just that test at Raceway Park. I was running a set of cut-backs, next week ran a set of stocks and lost .8 mph at the traps, the next week the cut-backs were back in and the old performance was back. BTW the trap speeds were normalized for weather conditions, so the comparisons from week to week were as valid as back to back passes on a single day.
I put around 10k miles on the Vette each year with quite a few 1/4 mile at a time and find I need regap my cut-backs around twice a year. A set will last around 2-3 years before the inside edge of the center electrode becomes worn down to the point where I feel the need to install a new set.
This "old dragracer's trick" works because it unshourds the flame front for better access to the charge and so more a complete burn.
I cut my stock AC Delcos back till the outer electrode is just at the edge of the center electrode. I use a std gapping tool. Since I'm running a Hyper Tech set up with performance wires I gap to .045"-.047" range and regap when they burn open to >.050".
Hi. There is an other aspect with having larger gap that is that the voltage rises to a higher level before the spark comes. Thereby is the islation in the coil more stressed especially in the stock coils.
hi there cplonner,7thvet,corvette kid,cfi-efi,comp,65z01,rick lambert,steel blue.
thanks guys for your help and comments r.e cut back spark plugs!
really appreciate it!
cheers
glen
sxyvet
Australia
I'm not sure if wider gap will stress the stock coil but there could come a point at which the coil simply could not build enough voltage to jump the gap. Remember too that with the stock L98 HEI the output drops off pretty much after 5k RPM. This is not a problem with a stock TPI setup since intake runners limit effective power to around 5k RPM.
I went to the HyperTech setup since I modified my TPI to provide good power to nearly 6k RPM and so now need reliable firing up there.
While this is true, it isn't really pertinent to the subject, because cutting back the ground strap, electrode, of the spark plug doesn't change or place limits on the gap.
