CFI-EFI, a few ?'s
Old Nov 19, 2006 | 04:03 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
Default CFI-EFI, a few ?'s
i have an '84 with the CFI. i also have a second CFI engine. i want to build the one not in the car up to about 400hp 450ft/lbs tq. is this possible? i want it to have that power, decent fuel mileage and it has to be reliable. also i am on a budget, but if i have to i can wait for the $$ to come in an then buy the parts, so that isnt too much of a problem. i have no time limit to get this done either.
any help will be appreciated
Old Nov 19, 2006 | 04:24 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I'd go ahead and start planning your block build and look for some better heads. I'll let CFI-EFI tell you if he thinks the stock intake set-up can be modified to this level, or if you should look for something else up there too.
I'd also be thinking stroker for sure, especially considering the torque level you're seeking..
Old Nov 19, 2006 | 04:27 PM
Grease Monkey
what is a stroker? i have heard it but never looked into it
Old Nov 19, 2006 | 04:34 PM
SHINOBI-X's Avatar
SHINOBI-X
The CFI system even heavily modifed using a stock intake has never seen 400chp from anyone(that i've ever heard of). 400chp from a 406,X-Ram,bigger TB's,larger port heads,headers etc is about it. This is naturally aspirated of coarse.
Old Nov 19, 2006 | 04:35 PM
Corvette Kid
See this thread re/ strokers.
Old Nov 19, 2006 | 04:50 PM
Grease Monkey
thanks for the stroker info. how much power can i get out of my CFI with the external looking original? i also want it to be NA w/o NOS. i know bore & stroke, cam, ported heads, etc. also what does blueprinting mean?
Old Nov 19, 2006 | 06:00 PM
JLeatherman's Avatar
JLeatherman
A stroker is gonna be the only way to go. An Xram manifold uses the stock air cleaner and with the air cleaner on most people can't tell the difference. I would have to say that even with an ExtrudeHoned manifold (most ported you can get a stocker) that kind of HP isn't possible. MAYBE a stock manifold that's ported and siamesed could achieve that, but the tuning would be quite hard and I'd imagine driveability would suffer needlessly.
PS-Blueprinting means taking something and making it absolutely precise to the original specifications. Manufacturers have tolerances on mass-produced items and by taking the mass produced item and decreasing the tolerance (making it more precise) you get more performance out of it.
Old Nov 19, 2006 | 06:38 PM
Corvette Kid
Blueprinting is just as what's been described. But except for class racing, I don't consider a full blueprint extremely important. However, part of blueprinting could be considered the balancing. And this is very important for any serious performance build. Also if funds allow, I'd consider a full neutrally balanced crank. This would also require a neutrally balanced flex plate or flywheel too, whichever is required for your application. The standard crank balancing for SBCs is neutral on the front half and externally balanced in the rear. This is less than ideal. Optimum neutral balancing and the lightest, yet durable components you can afford will pay ongoing dividends in overall efficiency, ability to rev freely and longer engine life, as well as minimizing parasitic HP loss. You may also want to consider maximumizing quench for some of these same reasons.
Old Nov 19, 2006 | 08:03 PM
CFI-EFI's Avatar
CFI-EFI
I agree that 400hp 450ft/lbs tq. from a stock Crossfire intake manifold casting will be a severe challenge, but an "ExtrudeHoned" manifold is NOT the most ported you can get a stock Crossfire intake.
I really can't answer your question. So far, I haven't opened up my engine. It has 160,000+ miles on it, and except for porting the intake manifold, the engine is all original. Tom400CF had a Firebird with a junk truck 400 engine and the Crossfire off the 305 that came in the car, that ran really well. Ben 73 has done wonders, too. I have a spare engine that I am building up just as you want to do. The long block is ready for the final assembly, but the induction system has me stymied, too. The stock manifold won't feed what I've built. I am vacillating between using a vintage Weiand or Edelbrock Cross Ram manifold for a stock appearance, or abandoning the Crossfire concept all together.
RACE ON!!!
Old Nov 19, 2006 | 09:30 PM
Grease Monkey
thanks all
Old Nov 19, 2006 | 10:17 PM
Dominic Sorresso's Avatar
Dominic Sorresso
CFL,
Ben 73 and Elkabong both have Xfires that are over 400chp. Each is using the Xram, and a 383.
Based on my 105mph trap speed this October, my 350CID/3500lb Xfire is pretty close to 390 chp. Its very definitely at 450+ctq. That's using a ported Xfire manifold that's been Extrude Honed. Each of these three motors has a different ECM than stock. Either an 8625(Ben) or EBL by Dynamic EFI (myself and el). Each of us do our own tuning.
Bottom line is it can be done. Anyone that tells you the Xfire manifold can't be made to perform hasn't tried. Takes work and time. Good luck.
Old Nov 20, 2006 | 04:57 PM
Grease Monkey
Originally Posted by Dominic Sorresso
CFL,
can you tell me what else has been done on yours? i just want to get some ideas
Old Nov 20, 2006 | 08:59 PM
Dominic Sorresso
Here's a recent summary:
http://home.comcast.net/~surrexi2/xf...Enthusiast.pdf
Overall, the Xfire is just a SBC with a different induction system. It responds to all the same things any SBC does. Cam/heads/headers etc. The heads and cam are matched. You start with the heads you'll be using and optimize them with a cam profile that complements the cylinder head flow. You understand you're using a Xfire manifold so this ain't no 7000rpm redline motor. And you work within those constraints. Don't try and make it something it isn't. One thing it does have it a sh*tload of torque.
The difference between this year and last year is a better tune worth 3mph in trap speed.
To CFI-EFI, a few ?'s
