OK, Does Removing The MAF Screen Actually Help?
Old Nov 19, 2006 | 08:00 PM
All2kool's Avatar
All2kool
Default OK, Does Removing The MAF Screen Actually Help?
Once a month or so I remove the Air Intake and lubricate the butterflies with a shot of Silicone. While I have it off, is there really a benefit to removing the screen from the MAF?
Old Nov 19, 2006 | 08:49 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Some argue that the front screen straightens the air for a more accurate reading. It also helps protect the MAF wire from debris.
The rear screen however, serves no purpose.
If it helps, it's not by any measureable amount.
Old Nov 19, 2006 | 08:50 PM
All2kool's Avatar
All2kool
Really? I was thinking of the screen closest to the intake, which I guess would be the rear screen. And how could debris get past the Air Filter?
Old Nov 19, 2006 | 08:51 PM
VtVette's Avatar
VtVette
This comes up every so often. From what I recall the general concensus is that it is not worth it. I recall someone a while ago had rented some dyno time and decided it was a goot time to do some testing and put the debate to rest. The result was that the differences in runs with and without the screens was so miniscule no benefit could be attributed to removing the screens.
I had removed the screens on my former '85 years ago. This time I decided not to. The screens protect the fragile wire from any debris that may get by the filter (unlikely but better than nothing) and some say the screen helps to even out the air as it passes through the MAF.
Debates still arise but after reading post after post on this issue I left my screens in on my current car.
Old Nov 19, 2006 | 08:56 PM
vader86's Avatar
vader86
yes, it will help an L98, but it isnt going to feel different, from a few small mods together you may feel something
on an LT1 it doesnt seem to help at all
Old Nov 19, 2006 | 08:58 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
I've heard arguements both ways, and actually have both. Bottom line though, you'll NEVER notice the difference.
Old Nov 19, 2006 | 09:00 PM
CentralCoaster
What's so special about the L98 that it would benefit it more than the LT1? It's equally marginal on both.
Old Nov 19, 2006 | 09:06 PM
vader86's Avatar
vader86
dont know, possibly a calibration issue
but i've seen many more LT1 people here who were hurt by the mod
and nearly everyone with an L98 either got something small or wasnt effected negatively
Old Nov 19, 2006 | 09:29 PM
lite blue's Avatar
lite blue
St. Jude Donor '12
When Chevy wanted to up the power from the '01 Z06 to the '02 Z06, they left the screens off the MAF, and decided that it did help.
Old Nov 19, 2006 | 09:52 PM
hippy's Avatar
hippy
So that was the only mod between an 01 and 02? Or did Cheby decide that they would save the cost of the screens and put in a cam that had 10* more duration???
Old Nov 19, 2006 | 09:54 PM
All2kool's Avatar
All2kool
To be clear - I am not looking for more HP - I'm looking for ways to improve fuel economy and/or efficiency of the motor. If making minor mods produces more HP, that is a bonus.
Old Nov 19, 2006 | 09:59 PM
cv67's Avatar
cv67
St. Jude Donor '05
I would just leave it. I noticed no difference...I would guess the LT1 might benefit from a little air "straightening" as it has some prety short runners, so airspeed would be a bit slower.....The TPIs are so long and the airpath so convoluted in the firstplace I cant see where it would make an appreciable difference.
Old Nov 20, 2006 | 02:19 AM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Different style designed/calibrated MAFS...what worked for newer cars,didnt mean it worked for the older ones.MAF design has changed considerably since the 80s...I see your point though,but doesnt mean it applies to the 80's MAF style set up.
The best all around MAF sensor for power and economy is a stock unit.The stock L98 set up cannot inhale enough air to justify it outside the TB area anyways...the stock MAF and airbox can feed it all day long before and never be a restriction.
Alot of GM cars since the 90s dont have MAF screens,but are an entirely different set up.They wouldnt work on an L98 either without some serious mods and programming.
Old Nov 20, 2006 | 11:37 AM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
unless you have lots of mods and race your car on the track, this mod will do absolutely nothing for you. Don't waste your time. (I think you said in the past you weren't interested in racing, etc)... so yeah... don't bother.
Also, you would be supprised what can get past the air filter, especially on the older L98's, the intake housing just doesnt seal as well as it should after many years of use.
Old Nov 20, 2006 | 01:07 PM
86PACER's Avatar
86PACER
Some say yes, some say no. I did mine anyway. It did not hurt anything, but I can't say I feel a difference from that alone either.
Old Nov 20, 2006 | 06:36 PM
steven mack's Avatar
steven mack
I removed my screens in my 85 and noticed a back fire in my exhaust when I would rev my motor until my car warmed up. I felt I got better miliage with the screens in and the car ran better I am looking for another maf with the screens in .
Old Nov 20, 2006 | 07:57 PM
CorvAdel's Avatar
CorvAdel
Yeah well I had been wondering about this topic too and had read opinions on it.
I have a mildly modded L98, flat-tops, stock heads, intake etc. but all ported, 211, K&N, cut lid, mail tune and so on and had been running a de-screened MAF since I built it, about 3000 miles ago.
Back then I got caught up in the hype of the so-called cheap h.p. mods...de-screening was one, as was a 52tb, relocating the AIT sensor...I know a little better now, esp. after taking heed from some clever dudes on this forum..
So, after reading this post I decided to try for myself and fitted a new screened MAF...any difference..?
None that I can tell...it still spins up like before and pulls just as strong, and is still fun to drive...!
After trying this out, I wouldn't bother taking out the screens again, and risking any dirt getting into the wires causing damage...
The ultimate test would be a b4 and after on a dyno, though..
To OK, Does Removing The MAF Screen Actually Help?
Old Nov 20, 2006 | 08:07 PM
_twisted_'s Avatar
_twisted_
If your not going to cut the heat sink fins down as well, dont waste your time just removing the screens
Old Nov 20, 2006 | 09:30 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
I removed my screens & sucked in a squirrel. A life would have been saved if I kept the screens
Old Nov 21, 2006 | 01:06 AM
86PACER's Avatar
86PACER
Pics? How did it get past your air filter?
