Someone has a Dana 36 center section for sale this is what the ad says:
Center section w/ 3.75 gear set in like new condition. Ready to be installed. DANA 36 for auto trans
What do I need to install this in my 87 vette and are the gears too steep for a daily driver. Thanks for your help
Re: Need help with center section purchase!!! (Wordguy)
All you need to do is swap the center sections and correct the speedo and you are good to go. 3.75 gear is not too steep for street driving, but I would be reluctant to use it in an L98. You have enough torque down low where even the 2.59 gear is not bad at all!
Good Luck,
