Automatic Transmission Problem
Old Nov 23, 2006 | 01:38 PM
ralph Thomas's Avatar
ralph Thomas
2nd Gear
Default Automatic Transmission Problem
Help:
I have a '92 vette with auto trans. Recently, when it is placed in park it doesn't lock the wheels. It has rolled out of parking spaces when left in park with out the emergency brake applied. Sometimes it stays in reverse and doesn't gear into park although the shift does lock in.
Any help would be appreciated!
Old Nov 23, 2006 | 01:40 PM
Pete K's Avatar
Pete K
Shifter linkage needs adjustment. It is adjusted at the trans where the cable hooks to the bracket. Loosen the nut and move it a little bit and re tighten.
Old Nov 23, 2006 | 02:06 PM
A95Y's Avatar
A95Y
Maybe you ran over something and bent the bracket.
To Automatic Transmission Problem
