Line Loc for a C4?
Old Sep 24, 2001 | 03:56 AM
Eric94's Avatar
Eric94
Default Line Loc for a C4?
Anyone have this mod? I'd like some idea on how to install this, so I can keep from killing the rear brakes while warming up the rear tires. Thanks. :seeya
Old Sep 24, 2001 | 09:42 AM
jimbjr's Avatar
jimbjr
Default Re: Line Loc for a C4? (Eric94)
A lot of guys are running it (me too!) I can not help you on the installation (had it installed) but I believe it is pretty easy and it works great.
Jim
Old Sep 24, 2001 | 09:54 AM
Hutch's Avatar
Hutch
I had a TCI unit installed in my '96. Cost me an arm and a leg because I wanted a custom installation with the unit hidden away from view and some safety considerations added. Probably not worth it but its pretty cool to have. You have to be careful about not messing up the ASR on these cars. That's why I didn't install it myself.
Line Locks are much more useful on auto trans cars to help with staging. With 6-speeds like mine I use it to warm up the rear tires without destroying the brakes. Good for burnout contests, too, I guess. :D
Old Sep 24, 2001 | 03:46 PM
Eric94's Avatar
Eric94
Come on guys, I need some install instruction, or pics. :seeya
Old Sep 24, 2001 | 07:42 PM
KNCRSR5R's Avatar
KNCRSR5R
Hey Erik......
I will send some ifon your way as I am also looking for the same info!!
:cheers:
Old Sep 24, 2001 | 07:43 PM
KNCRSR5R's Avatar
KNCRSR5R
Default Re: Line Loc for a C4? (KNCRSR5R)
Sorry.....habbit........Eric :crazy:
Old Sep 25, 2001 | 12:01 AM
hookedup's Avatar
hookedup
I recently installed the Hurst unit on my '92. The easiest way I found was to trace the line from the master cylinder for the front brakes(F) down under the car to where the frame kicks out in the driver area. Cut the line, double flare with 1/8 tubing fittings, install the line lock unit and bolt it to the frame with a ground wire attached. Wire the switch to your favorite location, bleed the front brakes and have fun! Dave :flag
To Line Loc for a C4?
