Craig Moates Software Updated...
Old Sep 24, 2001 | 09:46 AM
Rich B.'s Avatar
Rich B.
Default Craig Moates Software Updated...
...Just saw this at DIY-PROM...
http://members.tripod.com/moatesenhe...mecm/index.htm
...If you don't use it, just disregard this post... :D
Old Sep 24, 2001 | 11:43 AM
GlockLT4's Avatar
GlockLT4
Default Re: Craig Moates Software Updated... (Rich B.)
:cool: thanks..
Old Sep 26, 2001 | 04:02 PM
Rich B.'s Avatar
Rich B.
Default Re: Craig Moates Software Updated... (Glock'94)
Curt -
There's a couple posts at ThirdGen.org about problems with v81. I can't get in there right now, but here's what I emailed Craig:
I just tried v81; it seems to work OK in diagnostic mode, L98 Corvette 1227165 running, pages 1 - 5 all return readings (not sure if accurate or not!). But it is working, showing running values.
The Dump to File doesn't work correctly. Running or off, it won't dump. The default of being in non-ecm mode (or whatever) should probably be reversed, so that default is On for dump. Anyway, by resetting the setup defaults, I can get to a window where it seems it should dump, but nothing happens. vE6B004 works OK for this dumping.
I'm running Win98 w/98 lite on a Compaq 486DX50 laptop. All runs taken from the Windows desktop shortcut to the Win directory.
If you get it to run (or not), drop Craig an email and let him know. :yesnod:
To Craig Moates Software Updated...
