Opti-Direct Ignition System
Old Nov 26, 2006 | 12:51 AM
Ruff Rider's Avatar
Ruff Rider
Default Opti-Direct Ignition System
Has any-one got one of these http://www.delteq.com/
If so how do you like it ????
Old Nov 26, 2006 | 01:44 AM
Ttime's Avatar
Ttime
I'm curious too. Here's a bump.
Old Nov 26, 2006 | 01:51 AM
bogus's Avatar
bogus
a number of folks have them. I have heard generally good things.
I have heard some questions about later LT1s and the workability, but I don't know the causation - was it installation failures? is it an incompatibilty issue? I donno.
Old Nov 26, 2006 | 03:26 AM
93-383's Avatar
93-383
From what I have herd this system only helps with the carbon tracking under the cap of the OPTI the reliability issues of the OPTI as a sensor are still a factor since the coilpacks get still get their information from the sensor part of the OPTI. Personaly it seems like too much cost for little improvment over some of the new aftermarket OPTI units
Old Nov 26, 2006 | 03:44 AM
Ruff Rider's Avatar
Ruff Rider
$$$$$$$$$$$ ALOT
I'm replacing my OEM water-pump with a Mezie HD, so I feel ok sticking with a stock opti for the $$$
Old Nov 26, 2006 | 07:21 AM
Tom Piper's Avatar
Tom Piper
I love it.
I took the rotor out of my OEM Opti-Spark and run the Delteq.
Tom Piper
Old Nov 26, 2006 | 09:42 AM
Lone Ranger's Avatar
Lone Ranger
DelTeq uses technology from the Cadillac NorthStar, doesn't it?
Old Nov 26, 2006 | 09:57 AM
Tom Piper's Avatar
Tom Piper
Correct.
Tom Piper
Old Nov 26, 2006 | 10:06 AM
LT4BUD's Avatar
LT4BUD
Originally Posted by Tom Piper
Correct.
Tom Piper
Will the Northstar system fit into an LTx motor.....
A question asked out of pure ignorance..so it is probably pretty stupid..
Old Nov 26, 2006 | 11:03 AM
ZBRA's Avatar
ZBRA
Tom Piper
I have a Delteq that I will be installing when I reassemble the motor in my '94.
I have a question on rotor removal. Just open the opti, pull the rotor out, and close the opti back up? That simple?
Old Nov 26, 2006 | 11:21 AM
Tom Piper's Avatar
Tom Piper
A simplified explanation is the Delteq box converts Opti-Spark signals into signals that are the same as the Northstar crank sensor creates. These converted signals are then feed to the NorthStar coil pak.
All the Delteq does is create a "window of opportunity" for each coil in the coil pak to fire, the same ignition timing signal that is created in the LT1/LT4 PCM from the Opti-Spark still fires the coil. So, the timing does not change from the stock Opti-Spark. The Delteq just eliminates the need for the cap-and-rotor part of the Opti-Spark.
I'm running it on my LT1 now -- Delteq makes a kit to bolt on.
Tom Piper
Old Nov 26, 2006 | 11:25 AM
Tom Piper's Avatar
Tom Piper
The rotor, when screwed down, holds the Optical sloted disc in place.
Without the rotor, you have to make sure the screws hold the disc in place -- I used special washers, there are other ways. I think you can find some by doing a search.
Tom Piper
Old Nov 26, 2006 | 05:27 PM
ericcer's Avatar
ericcer
I have it on my 96 and love it. It is a better ignition/spark system than to OEM design. It is much easier replacing spark plug wires too. Great customer service.
Old Nov 26, 2006 | 05:43 PM
lefoy84's Avatar
lefoy84
Is there any performance increase?
Old Nov 26, 2006 | 08:30 PM
Red Rocket's Avatar
Red Rocket
Installed the Delteq in my 396 LTI and took out the MSD box. Picked up 15 RWHP from 6200-6500 RPM's and no more opti failures at the track at 6800 RPM's. Two years of service with no problems.
Old Nov 26, 2006 | 08:44 PM
JJ 86's Avatar
JJ 86
I've got the delteq on mine and love it. A lot smoother idle from it as well. Not to mention the ease of replacing plug wires too.
Old Nov 27, 2006 | 12:47 PM
93Quasar's Avatar
93Quasar
I've got a couple of questions for those experienced with this system. I'm fed up with my car eating opti's so I need to do something different. But with what I think is yet another failed opti, I'm curious what part of the opti has to be functional for the delteq system to work. I have no idea what is killing the opti's on my car - heat? rpms? They never get wet. But I've put one on every year I've had the car with maybe 1-2k miles per year driving. Usually fail with either code 16 or 36 (I think that's the numbers - one is hi-res pulse failure and one is low-res pulse). Anyway, I thought those failures were in the optics, which according to delteq's website is actually the more robust part of the system. I guess what I'm after is if I'm blowing the optics out of these things, then will the delteq do anything for me? And if my current opti is on the blink, will I have to replace it first? I'm looking for a solution, but based on my understanding of the delteq and how it relies on the opti pulse, it won't fix anything for me, or will it?
To Opti-Direct Ignition System
Old Nov 27, 2006 | 02:30 PM
Tom Piper's Avatar
Tom Piper
Originally Posted by 93Quasar
...Usually fail with either code 16 or 36 (I think that's the numbers - one is hi-res pulse failure and one is low-res pulse). Anyway, I thought those failures were in the optics, which according to delteq's website is actually the more robust part of the system. I guess what I'm after is if I'm blowing the optics out of these things, then will the delteq do anything for me? ?
No
And if my current opti is on the blink, will I have to replace it first?...
Yes
Old Nov 27, 2006 | 02:51 PM
bacardioil's Avatar
bacardioil
I use the delteq also. very good. Have had no problems.
Old Nov 27, 2006 | 04:18 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
15 RWHP over what?
Larry
code5coupe
