ZF conversion, need help!
Old Nov 26, 2006 | 11:03 AM
BLWN BUX's Avatar
BLWN BUX
Default ZF conversion, need help!
Hi All:
I have an 89 Convertable, with a S.C. 383
I am in the middle of changing my 700R4 to a ZF 6 Speed.
I bought all the peices from a wrecking yard.
What am I going to need for a flywheel? (need a 400 type)
What will I need for a clutch? (Needs to support 500/500 RW)
Anybody recomend a scater shield bell housing as opposed to the stock aluminum? These L98 Motors realy don't turn many RPM. I usualy run under 6,000.
Thanks for the help.
Chad Tombyll
Old Nov 26, 2006 | 12:11 PM
BLWN BUX's Avatar
BLWN BUX
Looking at Aluminum Flywheels, any Input?
Thanks,
Chad
Old Nov 26, 2006 | 02:58 PM
Mr6spd's Avatar
Mr6spd
Thanks,
Chad
Chad,
Later tonight I plan to list the flywheel you need in the C4 Classifieds. It is a new custom Fidanza aluminum flywheel made specifically for mating a ZF6 transmission to an 2 piece rear main seal small block. It is presently neutrally balanced, but has a machined attachment point for adding a balance weight to match 400 externally balanced cranks.
I also have a new Spec stage 3+ clutch rated for 800 ft lb that I plan to sell.
Old Nov 27, 2006 | 12:58 PM
Dominic Sorresso's Avatar
Dominic Sorresso
Thanks,
Chad
Fidanza FW with an SLP LT-1 Camaro 11" sprung hub clutch disc. Valeo PP. Some rattle at idle, but that's it. Quiet otherwise on an 84 Xfire. With a good tune it hardly rattles at all.
Old Nov 27, 2006 | 09:19 PM
BLWN BUX's Avatar
BLWN BUX
Thanks ,
Actualy I decided to go with a "RAM" conversion
It comes with a new slave cylinder conversion that will turn the PPlate into a pusher type. I am to understand that the puller type has limitation in the PP #'s . I am now getting a 2800#er with a dual friction disc and aluminum F.W. Shuold be good to 600RW
Thanks All
Old Nov 27, 2006 | 09:42 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
There is no need for a custom flywheel to put a ZF on a 2-pc seal block. Any 85-86 Corvette flywheel will work. I'm using one right now. The 84 flywheel might also work. For the same reason, I also expect that an 87-88 flywheel would work for a ZF conversion on any 1-pc seal block.
Thanks ,
Thanks All
Excellent choice. Anything is better than the pull type pressure plate and t/o bearing.
Old Nov 28, 2006 | 12:22 AM
Mr6spd's Avatar
Mr6spd
[QUOTE=CentralCoaster]There is no need for a custom flywheel to put a ZF on a 2-pc seal block. Any 85-86 Corvette flywheel will work. I'm using one right now. The 84 flywheel might also work. For the same reason, I also expect that an 87-88 flywheel would work for a ZF conversion on any 1-pc seal block.
QUOTE]
I pulled a 4+3 out of an 1985 vette ... Trying to use the stock 85 flywheel, There is not enough room for a sprung hub disk to clear the crankshaft bolts. The recess is simply not deep enough.
I had read before on ther Forum that you could use the stock 85-86 flywheel, So that was my plan. But there was no way it would actually work.
Are you using a non-srung hub disk with the stock 85-86 single mass flywheel? Or did you find a special sprung hub disk that is not as thick as the normal? The SPEC disk that I have sure won't fit with that flywheel.
Old Nov 28, 2006 | 01:29 AM
CentralCoaster
I'm using the 85 flywheel with the ZF6 (springless) clutch and pressureplate.
I'm not sure what clutches work. I know the Camaro clutch has a smaller hub. Clearing the crankshaft bolts isn't the concern (the stock clutch's large sprung hub obviously clears them), it's whether or not the hub clears the pressure plate.
I'm not familiar with the 1-pc crank setups. If it helps, I have a list of the parts interchangability between years. I also measured everything on mine for future reference. I wonder if that RAM setup or new Mcleod setup will work on 2-pc cranks. The only reason it wouldn't is if the crank extends futher back.
Old Nov 28, 2006 | 01:33 AM
JLeatherman's Avatar
JLeatherman
He said it's a 383. Therefore it needs an externally balanced flywheel which means he can't use the stock flywheel. I just went through this with my engine and ended up going with a Hays.
Old Nov 28, 2006 | 01:36 AM
CentralCoaster
I presume the original poster has a 1-pc seal crank, so none of our last few posts apply, I was just getting off topic. In fact, I'm not sure what the original poster has, he never said.
Old Nov 28, 2006 | 11:04 AM
Mr6spd's Avatar
Mr6spd
Actually, clearing the crankshaft bolts is the issue, as the spring side must face forward. (will not clear the Throw out bearing)
I know first hand from my friend's aggravating experience, that using a regular ZF non sprung disk with a single mass flywheel is a very bad thing. Others on the forum have made the same mistake. It is pretty much universally recommended on the forum, and by the clutch manufacturers, that you use a sprung hub disk with a single mass flywheel.
So to clear it up for all who are planing to use a 2 piece rear main seal engine: No, you can't use a stock 85-86 single mass flywheel, if you want to use a correct sprung hub disk.
Old Nov 28, 2006 | 11:27 AM
Thrak's Avatar
Thrak
I use a non-sprung clutch disc on a stock 85 flywheel (single mass) with my ZF6 and dont have any problems...
Just takes a good clutch foot...
Old Nov 28, 2006 | 11:39 AM
CentralCoaster
I've seen a lot of feedback from those with sprung hub disks, and they seemed to have very little effect on the trans rattle. I think I read somewhere (ZFdoc or G Killebrew?) that said the sprung hub clutch wasn't capable of silencing the ZF, and that's why they had to design a new flywheel. The dual mass flywheel spring is very different than a sprung clutch.
On the other hand, there's a huge difference between single mass aluminum flywheels and stock single mass grey cast iron flywheels, regarding the trans rattle. The iron fw is much heavier and dampens better. Which did your friend use?
My car has noticeable rattle at warm idle in neutral, particularly when parked next to a wall, but the transmission noise at all other times is insignificant. I'll confess that I haven't ridden in any ZFs with a sprung clutch or dual mass alum flywheel.
Old Nov 28, 2006 | 11:47 AM
Mr6spd's Avatar
Mr6spd
My friend used a 13lb aluminum flywheel ... but the 85-86 iron flywheel is lightweight at only 15 lb ... not a big difference.
The clutch disk configuration results from my friend's '91: 1) Solid disk, 2) Mcleod disk with 1/2 over molded springs (semi-rigid), 3) sprung disk with springs only.
Observations:
-Idle Gear noise was not much differnent between the three clutch disk types.
-Noise and vibration under load at low rpms (under 2500) in 5th and 6th gear: Dramatic differences between the clutch disks. Solid disk was by far the worst, Mcleod was better but still not great, spring only disk was much better.
Old Nov 28, 2006 | 12:14 PM
Dominic Sorresso
There's a big difference in mass between the AL and Iron FW. The AL spins up so much more readily. I was originally going to use the 84 FW but found that it required a "modded" ZR-1 clutch fork pivot. That's because the FW is thin and the fork needs the extra travel to engage the disk. Otherwise the clutch grabs right at the bottom. And I didn't want to do this all over again, so I took the plunge on an AL FW. Fidanza makes FWs specifically for both the 2 piece and 1 piece cranks retro-fitting the ZF trans.
Old Nov 28, 2006 | 01:12 PM
Thrak's Avatar
Thrak
Thats interesting because I do get ALOT and I mean ALOT of vibration and noise in 6th gear under 2000rpm.... now I know why.
But 5th isnt bad, and the rest of the gears are quiet.. I do get some trans rattle in N, but its not a big deal.
To ZF conversion, need help!
