11s on the rear
Old Nov 26, 2006 | 05:18 PM
lefoy84's Avatar
lefoy84
Default 11s on the rear
Has anyone put 17X11 wheels on the rear of a vert? I want to know if the tires will stick out past the fenders,
Old Nov 26, 2006 | 05:48 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Depends on the wheel and year. 88 up with standard ZR-1 spacing about1/2 inch. 87 down should just fit.
Old Nov 26, 2006 | 05:49 PM
lefoy84's Avatar
lefoy84
Originally Posted by c4cruiser
Even if you use the Grand Sport 11x17 wheels with the 50mm offset, they will stick out some. The GS used rear fender flares to keep spray from going straight up in wet weather. Depending on the stiffness of your springs and shocks, you mayl get some tire rubbing against the top of the wheelwell.
The ZR-1 11x17 wheels have a 36mm offset and will stick out a good 1.5". The ZR-1 body was 3" wider at the rear than the standard C4 coupe or 'vert.
Thanks. That was what I thought.
Old Nov 26, 2006 | 06:28 PM
lefoy84's Avatar
lefoy84
What about the C6 18X10.5?
Old Nov 26, 2006 | 06:48 PM
c4cruiser's Avatar
c4cruiser
Old Nov 26, 2006 | 07:25 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
The 50mm offset doesn't stick out too much, maybe 1/4 inch on my car anyway.
Old Nov 26, 2006 | 08:52 PM
Vic'89's Avatar
Vic'89
Here is a shot of my 17x11 with the GS offset:
Old Nov 26, 2006 | 09:35 PM
Razor89's Avatar
Razor89
Here a pic of 11's on my Convertible.
Old Nov 26, 2006 | 11:43 PM
lefoy84's Avatar
lefoy84
Who makes the wheels and what is the offset? They don't appear to stick out. Any rubbing problems?
Old Nov 27, 2006 | 12:45 AM
sami85L98's Avatar
sami85L98
u need 36mm offset or ZR1 offset both are same, buy from ebay from AFS or call Tomzwheels (forum vendor), search "corvette 84-87" in wheels and Tire section on ebay.
Old Nov 27, 2006 | 07:28 AM
Kool88vette's Avatar
Kool88vette
I just bought the AFS ZR1 17x11 on Ebay. They look real nice and I got them in two days. They were $395.00 I haven't installed them yet. The wheels do not have any spacer or offset so I don't know if they will stick out too much. If they do I'll put the Grand Sport wheel flares on.
Old Nov 27, 2006 | 08:22 AM
Razor89's Avatar
Razor89
I bought them off of Ebay about Three years ago from AFS. They do stick out about a 1/4 inch but not bad.
No rubbing problems at all.
To 11s on the rear
