96 LT4 Recommonded Upgrades/fixes
(1) KN Filter (cut box? - maybe)
Good luck, that's a sweet car you've got.
Thanks for the advice!
With all the inputs, I think I will:
-KN Filter w/o cutting box
-Corsa system (at later date)
-Install drain tube around Opti-spark on water pump
and leave the rest alone.
Thanks to all....
Basically reading some of these replies sound like the subject being disussed was something fragile or was in a Lincoln Towncar forum. Nogoodsam, if you were going to do just a few mods that won't touch the motor then do the gear, the exhaust and maybe an air intake. You will notice a nice SOTP result from the gear, the exhaust will free up a few ponies and at least sound like you are driving a Corvette and the intake doesn't hurt anything at the worst. A Hurst shifter will also not harm anything and will give you a much better feel going through the gears. I also would say to put on the electric waterpump when you do decide to do the opti. Sounds like you got a great car and these won't do anything but add to your enjoyment of it.
