Cool Runnings
Old Sep 24, 2001 | 08:12 PM
wylie's Avatar
wylie
Default Cool Runnings
What can I do to help my 96 LT4 run cooler down here is good ole hot South Texas? Are there any kits to turn the fans on earlier or at an adjustable temperature? Will a lower temp thermostat help or will I just cause it to never cool? I am going to do major service on the system and would like to do it all at the same time... All advice appreciated...
Thanks,
[Modified by wylie, 6:19 PM 9/24/2001]
Old Sep 24, 2001 | 08:14 PM
Arjen's Avatar
Arjen
Default Re: Cool Runnings (wylie)
A few things are get a 160 therm, check and clean the radiator and yes there is a manual fan switch that you can get from http://www.ecklers.com I THINK...someone more exact will reply soon... :crazy:
Old Sep 24, 2001 | 08:18 PM
88L98's Avatar
88L98
Cruise-In II Veteran
What can I do to help my 86 LT4 run cooler down
how you like that 86 LT4 ;)
a 160 degree thermostat and reprogram the computer to turn the fans on earlier. im in TX too, and i have these two things and i never see above 185
[Modified by 88L98, 6:19 PM 9/24/2001]
Old Sep 24, 2001 | 08:20 PM
scorp508's Avatar
scorp508
I've got a 160 degree thermo, and my chip turns the fans on sooner. I also have a manual fan override switch so that I can turn them both on at will. My car needs a damn good beating in 95+ degree weather to ever see over 200 degrees. :D
Old Sep 24, 2001 | 08:23 PM
satyr7777's Avatar
satyr7777
Default Re: Cool Runnings (Arjen)
Hey neighbor-
Yep- there's lots of stuff that can be done, higher volume h20 pump, new aluminum radiator- (there's a nice one available from Tom Dewitt for $450, or one from Be Cool), there are switches that can turn your fans on earlier, and etc. It's all a matter of how much green you wanna lay out. My 94 will be getting a new radiator eventually, and probably a better h20 pump haven't decided on the t-stat. Don't have the $ right now- so it's staying stock for now- but this summer proved to me that I'll need to do something before next summer. :mad - John
To Cool Runnings
