Edlbrock high flow TPI base
Old Nov 28, 2006 | 05:28 PM
steven mack's Avatar
steven mack
Default Edlbrock high flow TPI base
Just bought an Edlbrock high flow base and AS&M large tube runners. I am putting them on a 350 with World Products sportsman II heads with LT4 cam and 1.6 rockers. The motor is supposed to put out 415 horse and 435 ft lbs torque. Is anyone running the same intake? It seems likethe base could use some cleaning up and porting. Has anyone run the same combination, and what is your opinion?
Thanks, Steve
Old Nov 28, 2006 | 05:30 PM
vader86's Avatar
vader86
The TPiS base is an Edelbrock base that has been cleaned up and ported.
I doubt that your combination will make the power you think it will.
Old Nov 28, 2006 | 05:32 PM
steven mack
Well its not exactly a stock 350. Its a build I found in Hot Rod magazine. It uses a 400 block zero deck 6 1/4 long rods, 327 crank and J&E flat top pistons with 10.5 to 1 compression. I am using a retro fit roller cam and lifters.
Old Nov 28, 2006 | 05:36 PM
vader86's Avatar
vader86
That is not my issue with the combo....
You've got a TPI intake thats stuck with an engine+heads+cam combo that wants to rev, TPI will kill it's power.
Old Nov 28, 2006 | 05:41 PM
steven mack
I agree it probably will lose some power, I got some good information off your site. There was one build I believe that got 400 horse and 500 ft lbs torque, but with a bigger cam. When I did my build I was afraid to go with a longer duration cam because of drivability issues, so I went a little more conservative. The engine in the magazine peeked at 5800 rpm. I doubt the TPI will go that high.
Old Nov 28, 2006 | 06:05 PM
Eike's Avatar
Eike
I have the Edelbrock base and a SR ... we needed 5 hours for porting the base ...
Old Nov 28, 2006 | 06:22 PM
steven mack
Thanks for the pictures. How about the runner ports? Got any pictures for that? And how much difference did your porting make?
Old Nov 28, 2006 | 06:31 PM
Aardwolf's Avatar
Aardwolf
Doing some cleaning up on mine:
I didn't want to change the shape, since I do not know a lot about what is best. The cleaning up took many hours. Click My Corvette Pictures, by my avatar for more.
Old Nov 28, 2006 | 06:34 PM
Eike's Avatar
Eike
I don't know the difference to unported base/runners. The engine was stock before changing cam/intake. The SR runners didn't need much porting as the pre-owner did some.
A view through the intake ...
Old Nov 28, 2006 | 07:40 PM
shotchkiss's Avatar
shotchkiss
We had to use some washers to space up the fuel rail on one of the bases we had, but it had SVO injectors on it. Don't know if stock injectors would have that problem.
Old Nov 28, 2006 | 08:22 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
The injector binding problem is because the edelbrock fuel rail posts are too short. You should definitely put washers in there to avoid damaging the injectors.
Old Nov 28, 2006 | 11:59 PM
steven mack
I was thinking of useing Lt4 injectors I believe they are shorter so they may fit but I will definitly check to see if they bind .thanks for the replys
Old Nov 29, 2006 | 12:20 AM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Thanks, Steve
Was this engine carbed dyoned at that HP?If carbed,any TPI you add will not make nearly that much.You may see an increase in torque though,and that would be even more killer on the street if thats where your engine combo will spend most of its time.Or torque may fall down but be fatter at a lower rpm band,which is ideal for a street engine.
Btw,if you didnt know,the older GM ZZ4 crate engine made 355 HP in carbed form.Its very similar to the 88-91 350 TPI engine since it uses the same stock D port heads.The ZZ4 cam helps some too,but slap on a TPI to a ZZ4 crate engine and it wont make the 355 HP the engine is famous for with the carb.Its not saying carb is better,just the TPIs dont flow the air carb intakes do...a miniram or similar efi intake may take it to there or more.
However,if you keep the TPI style,drive your cars everyday and dont see 4,800-5,000 rpms all the time,the cars gonna pull like a rocket with nothing but torque ruling your tires.If youre building a car to make the best times mostly on the track,then a different intake will be one of your mods.
Old Nov 29, 2006 | 03:03 AM
cv67's Avatar
cv67
St. Jude Donor '05
Old Nov 29, 2006 | 09:38 AM
steven mack
Bill, those are all good points that I have thought about, the reason I chose TPI is exactly what you said at the bottom of your post. The torque curve on the engine build is 400 ft lbs of torque from 2500 rpm all the way to 5300 rpm. So the flat torque curve makes the engine more fun to drive and thought it would be better suited for TPI.
Old Nov 29, 2006 | 09:40 AM
steven mack
Nice port work cuisinartvette! Is that a stock TPI manifold, or a aftermarket? Thanks!
Looks like a stock base, did you notice a large improvement? There is an article on comp cams that extrude honed a stock base and got numbers close to the Edlebrock base. I was thinking of porting my stock base and sending back the Edlebrock base. Thanks
Old Nov 29, 2006 | 09:52 AM
cv67's Avatar
cv67
St. Jude Donor '05
That was a stocker (89), plenty of meat on thos e for portig. Couldnt see spending a bunch of $$ for an aftermarket that still needs some work.
To Edlbrock high flow TPI base
Old Nov 29, 2006 | 10:55 AM
Eike's Avatar
Eike
No Problem with stock L98 injectors over here. With the shorter LS1 injectors I had to cut a few mm of the fuel rail posts.
Old Nov 29, 2006 | 11:14 AM
CFI-EFI's Avatar
CFI-EFI
If you wanted a fat, flat torque curve you should have left the stock 3.75" crankshaft in it. Why do you thinks guys are lining up to buy cranks like you've discarded, to build 383s? Based on what I've quoted you as saying at the top of this post, you went the wrong way. If you wanted an exercise in crank swaps, you could have built a 421 or a 434. Now THERE is torque!
RACE ON!!!
Old Nov 29, 2006 | 11:36 AM
steven mack
RACE ON!!!
I understand what you're saying, I have built a 383 before, and may build another one-but this engine combination does a lot of other things than just a 350. I originally built the motor for an 83 El Camino, but, I have a lot of money in the motor and the torque specs seemed like they would work well with tune port. I'm not ready to build another motor at this time.
