Have you cleaned the Throttle Body lately?? Also check the Throttle Positioning Sensor voltage, and Idle Air Control. I'm at work so can not give you the exact details at this time. I'm sure others will have the voltage needed at TPS. If not just do a search for each item.
Cleaned It With Carb Cleaner.
I've Never Seen Tb Cleaner.
I Did Remove The Four Prong Pluge And Cleaned Off A
Small Neddle And Seeat That Was Full Of Carbon.
Since the miss is regular clip a timing light in turn onto each wire and see if there is missed flashes that coincide with the engine miss on any wire.
This will either isolate a bad wire, plug, dist. or show that all is well with the ingition system.
If the miss cannot be isolated, look to the fuel delivery system. Verify that fuel pressure holds constant after priming the fuel rail and measure the resistance of each injector to see if any differ widely from the others.
You may want to take the ignition control module to autozone and have it checked, they start showing the signs of failure most often after the engine temps rise. They'll check it for free, if I remeber right they're 30-40 bucks.
Will Try It This Weekend
I Have Changed The Fuel Pump, Maf,full Tune Up, Checked The Presure At The Fuel Rail, And Changed The Gaskets At The Tb, And Plenum. Cleaned Tb, And Replaced All The Vac Lines.
The Last Owner Let The Car Go.
Cleaned TB, Checked all injectors with ohm meter and came up with a constant 17.6 ohms. Checkked all injector leads with a noid light all lines came back good. Replaced module in distributor, and checked wires with timming light.
No change at all. The car is still missing in gear at 6 to 700 rpm in gear.
