Slow starting...
Where do I start checking?
Thanks for the input.
...they significantly helped my start up and the car runs like it should now, especially after upgrading the wires to Accel 8.8mm and changing dist cap/rotor.
Dave
I promise i'll make this short.
I asked him to start it up, and he said oh it doesn't run, but he assured me it didn't need much to fix it. I gave him my phone number and left.
The following saturday, he asked me how much i'd give him, and I said if it doesn't run, $85oo he said if you are here with a check within 3 hours, it's yours.
we pushed it down to my house, and I was going over things, and there was no oil in it.
So I put in a quart, and it still didn't show. I added 5 quarts b 4 the
dip stick read full. My wife came out of the house and said give me a ride.
I told her it didn't run, and she was upset. I got in the driver's seat, to show her, and it fired up after a bit of crankingRrRrRrRrRrRrRrRrRr
only later talking to a guy at the car show did I find out that the oil pressure switch is the secondary means of energizing the fuel pump.
I changed the fuel pump relay, and zing!!! started up every time!!
Sooo check the voltage at the pump, the relay may be high resistance,
or a bad ground at the pump causing it to run slow, not bulding up pressure as fast.
oh, the reason it didn't have any oil in it was because he changed oil, and only finger tightened the drain plug and in the process of moving, and not driving the car for 2 weeks, it all leaked out.
That's all I got but that relay saved me $5500
Try and hold the accelerator to the floor next time when cranking.
Good story coupeguy2001. (thumbs up)
Here is the fuel pump relay on a 86 and should be the same for 91.
