Is this a good BOLT-ON Modification list for a 1995 Corvette Convertible?
Re: Is this a good BOLT-ON Modification list for a 1995 Corvette Convertible? (Andy1983)
Yes it looks like it.. you have a 4L60E in your 95.
you also get to pick the stall speed.. like I said in my opinion a 2600rpm stall should be fine.. if you go with a loose 2600 it will be closer to 2800rpm I believe.
Jeff
Jeff
Re: Is this a good BOLT-ON Modification list for a 1995 Corvette Convertible? (-=Jeff=-)
the v-1000 is the correct one.
2 weeks ago/slick track.EVERYBODY running slow!!!
5 runs..slowest 13.40x
fastest 13.35x
runnin with 3/8 tank of gas, jack and spare in place.
60' times were ALL 1.82x
speed at 1/4 mile was 101.xxx
A torgue converter is a torque "multipyer"
a higher stall rating allows the car to remain at an optimum rpm rage longer.
excessive wear should not occur during normal operation, or unless the car is abused. I agree that if you already have 3.07 gears, that you might consider a converter 1st.
many exhaust experts might recommend keeping the stock cats for now, as aftermarkets are only marginally better than cats from a 95/96.
my next mod may be long tube headers, but im kinda holding off to see how bad the econamy/recession gets :mad
fastest 13.35x
Received 4,684 Likes
Re: Is this a good BOLT-ON Modification list for a 1995 Corvette Convertible? (Phil-tha-Rush)
I have a Hypertech PP+ for a '95 Vette in case you're interested. I'll let it go for $199 delivered to your door. Email me at david.grover@***.com if interested.
Forget the Granatelli, forget the air foil, and forget the ram air. Save yourself lots of money. The throttle bypass, K&N, open lid, Hypertech programmer, theromosat 160 degree are all good. Oh yes, the Corsa is your best choice for exhaust.
