Sport seat question
Old Nov 29, 2006 | 08:17 PM
JD94Vette's Avatar
JD94Vette
Default Sport seat question
What is the usual problem with 92' sport seats when all quits?
John
Old Nov 30, 2006 | 12:18 AM
Dads90's Avatar
Dads90
If the seat motor runs and the track doesn't move, the nylon gears in the drive assembly have broken off. Pretty common. You can buy a rebuilt one.
Old Nov 30, 2006 | 08:10 AM
mikey whipreck's Avatar
mikey whipreck
wrong thread... ignore me
Old Dec 1, 2006 | 08:32 PM
JD94Vette's Avatar
JD94Vette
everything is dead. Seat moves back and foreward but the sport seat part does nothing. What is that?
Old Dec 1, 2006 | 08:43 PM
Travis93's Avatar
Travis93
Bad connection or pump motor posably. Is it the lumbar or side bolsters or both not working.
Old Dec 1, 2006 | 09:18 PM
RED92LT1's Avatar
RED92LT1
Are you referring to the bolsters?
Old Dec 5, 2006 | 06:11 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default seats
pop the seat bottoms off, and check the plastic tubing for tightness, and make sure the connectors are tight and the wires are snug in the connectors. (you did know all that junk was under there didn't u?)
There are relays in the bolster control unit that may go bad. even check the fuses first, then the relays.
If all are good, it could be a bad pump. but most likely since the motor and pump are intermittant duty, and they don't run very long, it's a relay.
(specially if you are totally enjoying your ride and you have your sunglasses just right and are trying to look cool playing with the seats.)
If the pump runs, and nothing really happens, it could be a bladder but that's a last resort
To Sport seat question
