Exhausting Problems...
Old Sep 24, 2001 | 11:06 PM
Nomar116's Avatar
Nomar116
Default Exhausting Problems...
Im trying to quite down this 383. I have hooker headers with the hooker Y pipe, into a gutted cat, into a pair of Monza resonator tiped pipes.... The car seems to be making alot of noise directly under the center of the car at idle, around the Cat, while under heavy throttle the car opens up and sounds great. The problem is around 1-3k the car resonates so bad I worried it's going to rattle the teeth right out of my head :crazy: So what would you guys suggest? Id like to get away with only mufflers for now, or Ill have a muffler shop do the work....:smash: Can this problem be solved with some quite tips I want it to sound performance but right now at 20% throttle and 2k the car sounds like most street racers at WOT.... Unbareable What is a cheap and easy solution to this.... If there is one... :confused:
