fan switch question
Old Sep 24, 2001 | 11:07 PM
dt35th's Avatar
dt35th
Default fan switch question
just bought fan switch to turn fans on at 200 etc. My question is instruction sheet says not to put anything on the threads of the switch, it has sealant already on them, is this okay to do, or should i put teflon tape also. Switch is going into 88 with aluminum heads. Also are these switches self grounding. Thanks. :flag
Old Sep 24, 2001 | 11:45 PM
h rocks's Avatar
h rocks
Default Re: fan switch question (dt35th)
The "patch" from the factory is sufficient to prevent leakage. Don't make it harder than it is...follow the directions.
Old Sep 24, 2001 | 11:54 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: fan switch question (h rocks)
I think I used a little anti-sieze, some sealing and a conductor. Yes it grounds through the sensor body, but anyway it's in water (coolant).
BTW, that aux fan sw only turns on the Aux fan. The main fan relay is on the inner left fender well under the master cylinder. It doesn't take much wire to run a splice from one grn/yel to the other to bring both fans on with the aux can sw.
Old Sep 25, 2001 | 12:31 AM
KNCRSR5R's Avatar
KNCRSR5R
Default Re: fan switch question (65Z01)
Off the subject....i heard you can take a Radio shack swtich and hook it inline with the temp sensor on the block and then you have ON/Off capabilites at your finger tips?? True/Possible? :confused:
Old Sep 25, 2001 | 12:37 AM
scorp508's Avatar
scorp508
Default Re: fan switch question (KNCRSR5R)
Not the temp sensor. All you need to do is hook up a switch from the green/white wire on the fan relay to a groun (car's frame, etc...) and you have on/off at your fingertips.
To fan switch question
