Name That Part! 2!!
Old Nov 30, 2006 | 03:16 PM
Mekanic's Avatar
Mekanic
Default Name That Part! 2!!
Hey guys, I took my intake bellows off for the first time today to clean the MAF, I noticed something when taking it iff that I dunno wtf it is. Its a small white tube connected to what looks to be vacuum hose, that runs to the front of the engine, above the crank pully. What is it, Where does it go, and is it supposed to have vacuum going through it?
Here is a pic...just picture it as an LT4....and in a corvette...with straight bellows...you get it.
Old Nov 30, 2006 | 03:22 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Name that part?
How about "name the car that part is on"....
Larry
code5coupe
Old Nov 30, 2006 | 04:18 PM
C409's Avatar
C409
There was a fix for the earlier optispark distibutors to reduce moisture build-up from condensation in the distributor....the later ones came with a vacuum hook-up from the General . Yours appears to be the quick fix kit. Basically helps to draw air through to remove any excess moisture from the distributor also acts as a vent to allow bleed-off of any pressure building inside which would tend to cause oil leaks from the drive seal.
Old Nov 30, 2006 | 04:20 PM
ZBRA's Avatar
ZBRA
vent tube for the opti-spark
Old Nov 30, 2006 | 04:38 PM
rickneworleansla's Avatar
rickneworleansla
Originally Posted by rocco16
Name that part?
Larry
code5coupe
Corvaro?
Old Nov 30, 2006 | 06:17 PM
Mekanic's Avatar
Mekanic
ahh kickass, I knew I had the vented opti, just didn't know where it vented to, thanks guys
Old Nov 30, 2006 | 07:03 PM
drippingwithgold's Avatar
drippingwithgold
Name that part?
Larry
code5coupe
How about a Chevy Van
To Name That Part! 2!!
