I was thinking about replacing my injectors because they are original with STOCK units as my car is not heavily modified. Would adding better injectors and high performance fuel pump along with a 52 mm throttle body do much of anything or hurt the cars performance?
The reason we usually tell people to go with the Ford SVO 24's is because they are relatively cheap, they are plug & play, the computer can adjust to them without a chip retune (though an AFPR is helpful, and would still be helpful with stock ones), and because when a car is then heavily modded they'll be able to give the added fuel necessary whereas stock may not.
