scanner with camaro ecm
You can also purchase a code scanner and do the same thing. Only ability it will give is it will be able to erase the code without disconnecting the battery.
Either way your choice.
For example my AutoXray wants to know what year is the car and a specific VIN code number in order to determine which ECM is being scanned. In your case you would just enter the data for an '84 Camaro in order to setup the scanner.
Indeed to simply read stored trouble codes the paper clip method does NOT require knowing what version of ECM is present so long as it is the OBD-I style, which is certain since it's off an early-mid '80s Camaro.
Step 2.) Trouble shoot the codes as per your FSM.
RACE ON!!!
Do you have an exhaust leak before the O2 sensor?
RACE ON!!!
RACE ON!!!
POSTED @ 07:22 pm
POSTED @ 07:02 pm
RACE OFF!!
O2 sensors are good for 50~75k, but they have been known to go bad much sooner. They are sensitive units and the tips can become contaminated in use, creating erroneous feedback values or outright sensor failure. As mentioned earlier by two very good sources (and yet again), follow the FSM guidelines and check for a problem in the O2 wire and connector. If the wiring tests ok, a replacement O2 sensor can be bought at NAPA, Autozone, Kragen, etc. for about $20~$35.
You will need to disconnect the power to the ECM for 10 seconds to clear the codes in an 84 OBD1 and see if your troubleshooting has been successful. (Yes, RRT said something similar as well. But, he told you to disconnect the battery. I cannot say that your 84 has this capability, but at least by 88, the factory was putting an in-line fuse looking component on the battery connections, which when disconnected removes power to the ECM without disconnecting the battery from the car's other systems. Your radio presets remain, but all stored codes in the ECM are cleared. Additionally the later C4s and all OBD2 vehicles allow you to clear the codes with a scan tool. Unfortunately the early OBD1 systems just don't have that capability, whether you use a scan tool or paper clip.)
RACE ON!!!
RACE ON!!!
I thought *I* was the slowest typist on here. Generally I will see a post 15 minutes before leaving the post to author a two liner. And the way your post started. "Oh yeah...start working on the code 13 first.", right after I had said the same thing, sure makes it look like a "me too" post.
How clever...and original.
RACE ON!!!
If you don't know the age of the O2 sensor currently in the car, then given the relatively low cost of a new O2 sensor and the ease of replacing the old one, it might be in your best interest to replace it and see if that solves the problem. CFI-EFI will say that swapping parts is not good troubleshooting and he is absolutely correct. In some cases however, I believe in replacing some of the cheaper parts which wear out, like O2 sensors, when their age is unknown and it may save you more time than proper troubleshooting would take.
As CFI-EFI has so eloquently stated, "I'm wondering if you have you read the FSM? ... The answers to most of these are covered by reading the book." If you are going to troubleshoot your Vette, you NEED a factory shop manual (FSM). So much of the help you will get here assumes you have that excellent reference, so as to avoid making the really simple mistakes and wasting your time (and ours). First try reading the manual and if you don't understand something or have any questions, then ask, and I think you will find the answers are more cordial, because we know you are really trying to learn about yur Vette and not just get quick answers to save paying a mechanic. Unlike the other "repair" books out there the FSM is really an excellent reference and well worth the money.
No, and Yes. An O2 sensor doesn't "go bad in an open position" like a switch. If it is seen as an OPEN by the ECM, then either the ECM connector is bad (open or broken), the O2 connector is bad (open or broken), there is a break or open in the O2 connecting wire itself, or the O2 sensor went so bad its resistance in the circuit makes it appear to have an open or broken wire. While it could have failed in such a way that it appears to be an open, generally the O2 sensor itself fails at the tip due to an age or contamination problem and that produces an abnormally high or low reading. Given that a code 13 is reported and that you says it is sometimes intermittant, my guess is a problem with the wire from the O2 sensor or the connections.
The EGR has no operational connection to the O2 sensor that I am aware of which could have the slightest impact in the current situation. Same for the catalytic converter, so unless the guy who put it in disturbed the O2 sensor connection doing it, I doubt that your X Ram has anything to do with this issue.
