D44 D36 C-beam difference?
Old Dec 2, 2006 | 10:05 PM
JUAN J SANCHEZ's Avatar
JUAN J SANCHEZ
Default D44 D36 C-beam difference?
Is there a difference in c-beam from a D44 D36 car.I've got one that's 39.5" from center of outer mounting holes can't remember if it's from d44 or d36.
Old Dec 2, 2006 | 10:32 PM
bogus's Avatar
bogus
there is a difference... I will have to check my parts fiche to see if it shows measurements.
Old Dec 3, 2006 | 08:44 AM
Casethecorvetteman's Avatar
Casethecorvetteman
The DANA 36 c-beam is 15/16ths longer than the DANA 44.
Old Dec 3, 2006 | 10:00 AM
Zrxmax's Avatar
Zrxmax
Are to bolt patterns the same ? Can a 36 beam be modded to fit a 44 application ?
Old Dec 3, 2006 | 11:00 AM
Casethecorvetteman
Yes, it can be, the distance between the front and rear bolt holes is 15/16ths less on the DANA 44 c-beam, so if you used a DANA 36 c-beam with a DANA 44 you would need to drill new holes 15/16ths further back at the the tailshaft housing end of the beam in order to make it fit the shorter distance.
Have a look here, this is by forum member "JoBy"
http://www.joby.se/corvette/mods/2001-0X11_diff/
Old Dec 3, 2006 | 02:11 PM
C409's Avatar
C409
Default D36 - D44 C-beams
I am presently in the process of swapping a D44 into my 87 auto and have encountered the same dimensional problem with the beam being too long to allow the rear to fit the frame mounting brkts. Mine measured out @ 3/4" and like the others I redrilled the forward end (trans ) of the beam but I drilled @ 7/8" and am having the driveshaft shortened by 1" . I looked at Joby's pics and am concerned that he did not shorten it . On my car I could tell that the yoke was bottoming on something in the trans....most likely the speedo gear snap ring or retainer and rather than jam it in thought it would be prudent to take the d-shaft for a trim. All this as of yesterday afternoon (12-02) I won't get the shaft back 'til Monday so I'll have to fill you in later on my progress.
Old Dec 6, 2006 | 12:36 AM
Casethecorvetteman
If i were you and you wanted the job to go smoothly, which im quite sure you do, i would use the shaft and c-beam from a 6 speed car. It will fit on perfectly, there is no refabrication of parts, no mods, and no stuffing around. Simply remove and replace with the 6 speed parts.
Old Dec 6, 2006 | 09:08 AM
scranage's Avatar
scranage
I did the same thing, and although it looks like there is 1/8" just looking at the gap, it is in fact bottomed out. I also went with the 6 speed shaft in the end for fear of breaking something in the A4 tailhousing. I also used a redrilled C-beam. The next time I have that C-beam out, I'm going to trim the excess material off the end too.
To D44 D36 C-beam difference?
