What is more beneficial....
What is more beneficial, a high-perf cam, or a ram air system? What if I added 1.6 rocker arms along with the new cam? What about 1.6 rocker arms alone? Are 1.6 roller rockers an option? All of this is for a stock LT1.
On that note, is it difficult to replace the cam/rocker arms/roller rockers in an LT1?
TIA
[Modified by 92BAV, 1:33 PM 9/25/2001]
TIA
1 Post
Cruise-In III Veteran
Re: What is more beneficial.... (92BAV)
you can use the 1.6's with a new cam as long as it doesn't exceed the maximum lift for your valve springs. I honestly can't say what that is on a stock LT1 but have heard that even the 1.6's with a stock cam it's usually reccomended to replace the springs
Received 1,401 Likes
a new cam is better, but youll need some type of better cooling system too, exhaust and intake should be improved to let her breathe
Re: What is more beneficial.... (vader86)
-Sheppe
sorry dude, i rarely read sigs unless theyre on the earlier C4's
Stock LT1 heads cam benefit from a cam change. I have seen 356 RWHP on an LT1 automatic with bolt ons and a cam, no head work at all! This was a pretty agressive cam though.
Of course, this will not be optimal. For the best setup, you will want a camshaft, head, intake, exhaust package to work in conjunction with each other and compliment each other.
If you are going to go with a cam only, you will want new springs for sure. I would also suggest upgrading the studs to 7/16" and getting some Comp Cams Pro Magnum roller rockers. With these rockers, you will also need guideplates and at least hardened pushrods, although I would suggest chromolly pushrods.
Good Luck and let me know if I can help you with anything.
Thanks,
Thanks,
