LT4 oil change?
Old Sep 25, 2001 | 04:52 PM
96LT4's Avatar
96LT4
Former Moderator
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
CI3 Car Show Winner
Default LT4 oil change?
How many quarts, and which filter do you all prefer?
That's it for now. :D
Old Sep 25, 2001 | 05:13 PM
Crushinator's Avatar
Crushinator
Default Re: LT4 oil change? (96LT4)
I use the AC Delco filter with 4.5 quarts of Mobil 1.
Old Sep 25, 2001 | 07:07 PM
ghall's Avatar
ghall
Mobil one ----oil and filter-----great products.
Geoff Hal
Old Sep 25, 2001 | 07:17 PM
RichS's Avatar
RichS
Default Re: LT4 oil change? (ghall)
Mobil One oil, K&N oil filter.
Old Sep 25, 2001 | 09:10 PM
04Z16's Avatar
04Z16
CI 3-4-5-6-7-8-9-10 Veteran
5 Quarts Mobil 1 with a Fram Duraguard oil filter. The previous owner used the AC Delco but I have always had good luck with the Fram oil filters.
:seeya :flag
Old Sep 26, 2001 | 02:40 AM
JasonL's Avatar
JasonL
Default Re: LT4 oil change? (96GrandSport)
4.5 qts only brings the level halfway up the hatched mark on the dipstick, for me. I put in about 4.75-5qts.
Filter: AC Ultraguard, though I've also used the Duraguard and Purolator Pure One.
Old Sep 26, 2001 | 03:55 AM
vetsvette's Avatar
vetsvette
Default Re: LT4 oil change? (JasonL)
One jug of the Wal-Mart special Mobil 1 and Pure one filters.
Old Sep 26, 2001 | 08:50 AM
BlackTieC5's Avatar
BlackTieC5
Default Re: LT4 oil change? (vetsvette)
Check to see if Delco makes one of its GOLD filters for the LT4. I am using one on my LS1 - UPF-44
Old Sep 26, 2001 | 08:54 AM
GS470's Avatar
GS470
About 5 quarts 5W30 Mobil 1 and AC filter.
Old Sep 26, 2001 | 11:37 AM
96LT4's Avatar
96LT4
Former Moderator
Cruise-In V Veteran
CI3 Car Show Winner
Thanks for the info guys!!!! :cheers:
Old Sep 26, 2001 | 02:09 PM
Hutch's Avatar
Hutch
Try as you might, you won't get a full 5 quarts in an LT4. Mine takes a touch more than 4-1/2 quarts to fill with a new filter.
I run Mobil 1 10W-30, which I think is better for hotter climates and competition, but 5W-30 is probably the best all around choice. I try to change oil & filter every 2500 miles. Many will say that is excessive with modern synthetic oils but I consider it cheap insurance.
Personally, I don't think there is that much differenc between all the high performance oil filters out there. The specific brand isn't as important as frequent changes, IMHO. I do NOT recommend the toilet paper adapters, however. :D
To LT4 oil change?
