93 headlight dimmer switch problem
Old Dec 5, 2006 | 03:21 PM
MikeC4's Avatar
MikeC4
Default 93 headlight dimmer switch problem
I have a problem with my dimmer switch. When I pull the signal lever stalk to switch between High/Low I can't get the switch to toggle. I did remove the small plastic cover from the signal lever, and I found a small clip just sitting at the bottom of the cover. I looked inside the steering column and cannot figure out where this clip goes. Doe's anyone recognize this clip, or can someone please post a schematic of the signal lever stalk for a '93 ??? I just got the car last week, and here in Texas, the car will not pass inspection with just the Low beams working....... Also, the right/left turn signal, and cruise control functions properly. It is just the High/Low beam function that is broke.
Thanks!!
Old Dec 5, 2006 | 10:02 PM
MikeC4's Avatar
MikeC4
Help.....TTT.....?????
Old Dec 5, 2006 | 10:16 PM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
That is not an easy question to answer online
I would recommend you invest in a service manual
Best $100 I ever spent
Paid for itself many times
Old Dec 6, 2006 | 12:19 PM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
I believe that is the preload spring. It keeps pressure on the switch lock acuator rack. I don't see how that would effect your high/low beam problem though. I would suggest letting someone experianced with GM columns take care of it. If you want to tackle it yourself it's not really that difficult, but you will need a detailed diagram as well as a steering wheel puller and a lock plate tool. Since you're going to be into the column anyway, I would go ahead and tighten the bottom bolts on the tilt mechanism.
Old Dec 6, 2006 | 08:03 PM
MikeC4's Avatar
MikeC4
Ramrod,
Thanks for the insight. I think you are correct that this preload spring has nothing to do with the High/Low beam problem, as I noticed today that if I put the tilt steering in the uppermost postion, I can pull hard enough on the stalk to get the High/Low beams to switch! With this in mind, I am going to try to adjust the switch postion at the bottom of the steering column and slide it closer to the pushrod coming from the signal lever.
Thanks again and
To 93 headlight dimmer switch problem
