383 stroker vs supercharged
Old Dec 7, 2006 | 01:14 AM
franks96ce's Avatar
franks96ce
Default 383 stroker vs supercharged
im trying to make a decision on what would work best for my car.i have 96 lt1 auto.I would appreciate any suggestions.Ohh i forgot i have 109,000 miles on it.
Old Dec 7, 2006 | 01:33 AM
drochau's Avatar
drochau
383. Freshen up that motor a tad. Maybe even build it for boost and add a turbocharger later on.
Old Dec 7, 2006 | 02:00 AM
PurtyLilC4's Avatar
PurtyLilC4
While superchargers are fun, when adding boost to a motor with that many miles that on it that wasn't built for that purpose originally, you run a higher risk of damaging the already fairly worn parts.
Just my opinion, but I would freshen or even rebuild the engine before adding any type of boost. Doing this would also give you the opertunity to build the engine specifically for the boost application(if thats what you really want).
As for a 383, I love cubic inches as much as anyone else.
You can build quite a bit of power either, it all depends on your budget, and what you really want.
Old Dec 7, 2006 | 05:27 PM
jsavoy's Avatar
jsavoy
shore up your foundation before you're "forced" to...
Old Dec 7, 2006 | 05:34 PM
Pete K's Avatar
Pete K
Blowers are not for everyone. I had one and hated it. I am likely in the minority, but hated it nonetheless. Do the homework before making the leap. Owning a supercharged car requires a commitment. Be sure you are up to it.
Old Dec 7, 2006 | 08:05 PM
silver86's Avatar
silver86
I'm running 10 psi through my 134,000 mile 86E engine without a rebuild or even pulling the heads. Of course, my compression ratio is quite a bit less than yours (86E's run 9.0:1). But I agree that it takes a certain extra degree of commitment to run FI. But once setup, if done correctly, can be just as reliable as bigger cubes.
Old Dec 7, 2006 | 09:16 PM
93-383's Avatar
93-383
If money isn't an problem I would build a 327 all forged bottom and 8.5-1 compression and then turbo charge the hell out of it.
I only recomend the 327 because it is easier to build one to spinn at 7krpm+ wich will realy help the turbo
Old Dec 7, 2006 | 09:25 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
Pete, what was it that you didn't like about the supercharger? Did it hurt DD drivability?
Old Dec 7, 2006 | 09:28 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
i would go with the 383, that gives you room to add a SC on later
Old Dec 7, 2006 | 09:33 PM
AKS Racing's Avatar
AKS Racing
I think I recall that PeteK had the ATI P-600B and he did not like the whine of the blower. Not all models make the same noise.
I am a proponent of the SCed combos, and especially like the ATI head units. I currently use one of theirs to produce well past 20 psi boost on a fully built stroker. These are fun packages if you can get everything up and running properly. Mine is a very nice driver even with the solid roller, large blower, big cubes/heads, and the C4SP. Tuning is key.
Aaron
Pete K's Avatar
Pete K
It did alter drivability.
It added a ton of underhood heat
Made 101 decibles at idle
took quite a while to build boost. Especially during freeway driving.
Constant belt slippage issues
Actually made the car sluggish when not in boost because of the drag of turning the blower.
Blower located the aircleaner right next to the drivers side header.
Occasionally blew off any loose connection.
To 383 stroker vs supercharged
