LT1 to LT4 intake swap
Ok guys, me and a friend of mine have been comparing the Lt1's & LT4's. ( He has a 96 CE ) Anyway, is there a benefit in going with the LT4 intake on a basically stock LT1? Should a TB upgrade be done at the same time? Is the gain worth the time & effort of the install? I think if you port & polish the LT1 intake you can come up with the same gains. Any oppinions? :blueangel:
Re: LT1 to LT4 intake swap (ezmoney92)
Cruise-In I Veteran
Cruise-In II Veteran
Will not work...the runners are higher on the LT4 intake.:( You will have to change the heads too.
