Hey - I said it was over my head! No insults intended - I do know that I haven't been to a dealership in the last 20 years that didn't have the battery charger with jump starter sitting out. In fact, when I bought my '97 S10, they had to jump it and when I got it home, I had to leave it on the charger overnight - it was that dead (but I got a good deal and if I didn't make it home I had my Auto Club card!). As to this a/c thing, I don't believe the CCM has anything to do with it. The Processor is the Programmer. As far as I know, the CCM is merely a diagnostic link - it isn't the signal for anything and the Programmer calculates Temp door position and blower speed based on inputs from the Temp thermistors and desired temp signal from the Controls. Programmer also sends the a/c request to the ECM and that circuit is bridged by the Low Pressure Switch. ECM monitors Pressure Sensor for overall condition and high pressure; on/offs (Low Pressure Switch) for low charge. Foul ups (trouble codes) should be available through the Panel or Speedo and you can emulate the Controls with a bi-directional scanner through the CCM link. Hopefully code(s) will be retrieved soon so that we can help fix the problem.
I stand behind what I said, as we repair Corvette clusters, radios and CCM's for a living. There's more misinformation on the web about these parts than accurate info. GM built no protectection in these circuits from erant sparks for a reason. An 89 cluster has no relationship to an 84, 85 , 86, 87, or 88 cluster except the lower display boards are the same. You guys are guilty of reading some old info on the web and assuming it's gospel because it's there. And then, because I'm new to your forum some moron says I have no manners for printing the truth. Well, I think I've been pretty straightforward about it because I was trying to help the original poster avoid more problems by jump starting his car. You only do that as a last resort if you are stranded a long way from nowhere, but it's his car and he can do whatever he wishes.
If you repair clusters and radios and CCM's, then you should have access to their schematics and every C4 cluster has a MOV across the +12v line and it is located on the power supply board. Every radio has a zener diode across the +12v line and while I haven't seen a schematic for the car computer, I know for a fact that each has a voltage regulator to supply regulated voltage to the computer, and I am sure there is a zener diode on the +12v line to protect the computer and the voltage regulator IC. I have never read a post in C4 tech where someone jumped their car and then had any electrical problems. Dead batteries are jumped every day without incident. Jumping with reverse polarity will definetely do damage.
I don't understand how you can recommend charging your disconnected battery up and then reconnecting it but insist that jumping a battery is dangerous. The same voltage transient occurs when you do either. If jumping car batteries really can cause damage, then why don't car companies inform owners not to do so? Not one car manufacturer says to not jump a battery.
This is GM's advice for jump starting a C-4:
" If for some reason you have a low or dead battery be cautious when jump starting. When you attach the jumper cables to your battery and ground, wait about two minutes before trying to start the car. This allows voltage to power up the seven microprocessor's circuit boards. This helps prevent voltage spikes into the components."
About 10% of the clusters we repair have a defective IC caused by a voltage spike and we won't even get into the damage done to an alternator trying to charge a dead battery. Jump boxes should be banned at dealerships, but if they weren't I guess we would lose business. There is no built in protection!
Just for the record: I have jumpstarted my 86 more times than I care to admit and no harm has come from it.....that is obvious to me. Matter of fact never had a problem after jumpstarting any car.
Ok, so I finally get the blinking light again on the A/C. I push the fan buttons and it just comes up with 00. I'll just have to take it to my Vette guy and hope he finds it quick. Thanks for the help.
I have a 1990 six speed and have a similar problem (I pulled a CCM code 41 / loss of communications with ECM) ... one of the statements in the factory manual says that "if this fault is present, the C68 Electronic HVAC control head "OFF" LED will flash" ... don't know if the setup is the same on your year or not.
Just was curious to see if the dealership was able to get this fixed ... or not.
