Removing Light Switch Rod thing
Old Dec 9, 2006 | 02:04 PM
Hungryhippolw's Avatar
Hungryhippolw
Default Removing Light Switch Rod thing
Hey all. I need to replace my dash lights and the only thing that is stopping me is the pull rod thingie that turns on and off the headlights. How do I take it off so i can take the faceplate off of the dash so i can change the lightbulbs? The more detailed the better as i am new to doing this kind of thing. Thank you!
Old Dec 9, 2006 | 02:07 PM
AZC4Guy's Avatar
AZC4Guy
on my 86 the rod stays in place and just the plastic **** pulls off. Good luck.
Old Dec 9, 2006 | 02:09 PM
JAKE's Avatar
JAKE
There's a little opening at the very inboard part of the ****. Use a thin tipped tool, (I've used a eyeglass screwdriver) to press on a tiny tab inside that opening. That'll release the **** so it'll slide right off.
Jake
Old Dec 9, 2006 | 02:22 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Slide the tip of a flat-blade screw driver into that slot (show in the pic), press outward toward the know as you slide the know off the rod.
Old Dec 9, 2006 | 05:54 PM
5pinball's Avatar
5pinball
if the **** isnt comeing off easily. theres a spring loaded button on side of switch. push this in and whole shaft pulls out. you have to take off dash pad ,though to do it this way.
Old Dec 10, 2006 | 10:21 AM
nyernga's Avatar
nyernga
Hold onto the shaft with a small pair of channel locks then apply pressure to the tab behind the ****. Be forewarned though.......it will probably come flying off like a bullet so A) wear eye protection and B) Have someone as a spotter to locate where it went........
Old Dec 11, 2006 | 03:38 AM
raisinbran's Avatar
raisinbran
Dont break it. You will be hard-pressed to find a new one
To Removing Light Switch Rod thing
