build sheet on 1984
Old Dec 9, 2006 | 07:18 PM
ps374's Avatar
ps374
Default build sheet on 1984
Where is the general area where the build sheet is located on a 1984 Corvette.
Old Dec 9, 2006 | 08:59 PM
c4cruiser's Avatar
c4cruiser
There should be one on the top of the gas tank at the front edge. If you get under the car and look up between the spare tire carrier and the diff cover, you may be able to see it.
They are glued to the tank and the chances are that it will not come off without getting ripped. The paper will be very dry and you may not even be able to read anything on it.
You can always get a copy from the National Corvette Muesum along with a copy of the window sticker: https://store.corvettemuseum.com/ser...buildsheet.asp
Old Dec 9, 2006 | 10:50 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
i didnt find on on my gas tank of my '84. i have heard about one in the frame somewhere
Old Dec 9, 2006 | 10:57 PM
champs65's Avatar
champs65
I believe there is one in the right front frame rail, but I haven't been able to locate it.
My tank sticker on the 85 came off last year using a paint stirrer; about 90% complete with most of it faded, but legible.
Old Dec 9, 2006 | 11:14 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
It's inside the cradel, behind the frame rail. You Have to drop the cradle to get to it.
Old Dec 10, 2006 | 02:01 AM
NitrousSam's Avatar
NitrousSam
When we pulled the dash out of my 1984 we saw on the aluminum support mounting beam that the build date was written on it...my car was dated March something 1983 so it appears I have a a very early C4.
Old Dec 10, 2006 | 03:49 AM
86PACER's Avatar
86PACER
On my '86 it's on the inboard driver side right next to the steering joint. The plastic shield around the steering joint hid the hole from view.
Looks impossible to withdraw without ruining it in the process. I'd rather order a new one and leave this one alone.
Old Dec 10, 2006 | 03:02 PM
CFI-EFI's Avatar
CFI-EFI
Also, there is a tag on the rear of left door, below the belt line, with the build date. Mine was built in June of 1983. My VIN is in the low 11.000's.
RACE ON!!!
Old Dec 10, 2006 | 05:21 PM
RICEKILA's Avatar
RICEKILA
From: Beautiful Down Town "SWINDLEHURST" Long Island NY
The broad-cast sheet is in the left ( sometimes right ) frame rail. My build sheet was on the right side of the tank under the strap---
Old Dec 10, 2006 | 05:34 PM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
Originally Posted by c4cruiser
You can always get a copy from the National Corvette Muesum along with a copy of the window sticker.
It is so nice to have this available.
To build sheet on 1984
