lowering 95 corvette
Old Sep 26, 2001 | 04:01 PM
YellowC4's Avatar
YellowC4
Default lowering 95 corvette
I lowered my 95 corvette last week the front was even but the back on the right side was higher than the left side I checked the bolts they were even. does anybody no why please help :confused:
Old Sep 26, 2001 | 04:26 PM
Crushinator's Avatar
Crushinator
Default Re: lowering 95 corvette (YellowC4)
Is the ground 100% level? Sorry if that sounds stupid but the other day I was in the garage looking at my car :D and noticed the gap in the rear wheel well was greater on the passenger side then the drivers side. After an hour of measuring and remeasuring and trying to figure it out I realized I had it parked so the back passenger wheel was closer to the drain in the garage floor. :crazy: Just hoping it's something simple like that for you as well.
Old Sep 26, 2001 | 04:54 PM
YellowC4's Avatar
YellowC4
Default Re: lowering 95 corvette (Nat96LT4)
I drove it to a level ground and still the left back is lower by an inch than the right back the front is good
Old Sep 26, 2001 | 05:57 PM
enhance's Avatar
enhance
I heard losts of people saying that a lot of the corvettes come from the factory like this. I havn't checked on mine, but there has been other posts of this before. So this is normal, i guess.
Old Sep 27, 2001 | 02:17 AM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Default Re: lowering 95 corvette (enhance)
The 3 Vettes I was involved with a all were lower on the left rear after lowering. Yes the fenbers are different heights. Lower the right till they are even, drive around for a while, so it will settle, then get it aligned. Be aware that it will come up a little after aligning, as the camber will change. It should raise a little, not much after alignment. Steve
To lowering 95 corvette
