1991 l98/auto 'SYS" question
http://www.c4guru.com/articles/CCMCodePull.pdf
Ground terminal A and B of the ALDL connector. Turn the key on.
Code #12: Normal No Codes.
Code #13: Open Oxygen Sensor Circuit.
Code #14: Coolant Sensor Circuit Low.
Code #15: Coolant Sensor Circuit High.
Code #21: Throttle Position Sensor High.
Code #22: Throttle Position Sensor Low.
Code #23: Manifold Air Temperature Circuit High.
Code #24: Vehicle Speed Sensor.
Code #25: Manifold Air Temperature Circuit Low.
Code #32: EGR System Failure.
Code #33: Mass Air Flow Sensor High.
Code #34: Mass Air Flow Sensor Low.
Code #36: Mas Air Flow Sensor Burn-Off Function Fault.
Code #41: Cylinder Select Error.
Code #42: Electronic Spark Timing.
Code #43: Electronic Spark Control.
Code #44: Lean Exhaust indication.
Code #45: Rich Exhaust Indication.
Code #46: Vehicle Anti Theft Fault.
Code #51: Faulty Mem-Cal.
Code #52: Fuel Calpak Missing.
Code #52(1990-91 Corvette Only): Engine Oil Temperature Sensor Low.
Code #53: System Over Voltage.
Code #54: Fuel Pump Circuit Low Voltage.
Code #55: Defective ECM.
Code #62: Engine Oil Temperature Sensor Circuit High.
RRT Vette gave you the correct codes ...
Good luck ...
Use a paper clip to connect A & B together.
IIRC it doesn't work if you ground A & B. It may but the procedure calls for A & B to be jumpered together.
Do not start the engine.
Turn the key to the on position.
Count the SYS light flashes.
First should be 1 flash folled by 2 flashes. That's code 12 and is the default code even if there are no stored error codes.
After THREE code 12's the next error code will be flashed THREE times.
Count the flashes for the first number. Count the flashes for the second number.
Flash.....Flash Flash = 12
Flash Flash ...... Flash Flash Flash Flash = 24
After all the stored error codes are flashed THREE times the ECM will start over and flash 12 THREE time and the sequence just repeats itself.
It's crude but it works and it's cheap.
