Simple Question........
Old Sep 26, 2001 | 04:23 PM
Dave's_88's Avatar
Dave's_88
Default Simple Question........
When replacing the thermostat (just replaced mine with a new one) do you use a gasket or RTV? I couldn't tell what I was looking at when I removed the old one...too old.
Thanks,
Dave
Old Sep 26, 2001 | 04:31 PM
FoolCrzy's Avatar
FoolCrzy
Default Re: Simple Question........ (Dave's_88)
I used a Gasket and a small bead of permatex on each side of it. No leaks. I also like to let it set-up overnight...
Old Sep 26, 2001 | 04:55 PM
Nomar116's Avatar
Nomar116
Default Re: Simple Question........ (FoolCrzy)
I installed mine using both a gasket and rtv.... I used RTV to build up a sort of O ring in the recessed area of the housing on the manifold I believe it was. I prolly over did the sealant but Im one of those you cant have enough of a good thing I guess.... even though I know differently
Old Sep 26, 2001 | 05:07 PM
Vic'89's Avatar
Vic'89
Dave
Use both the gasket and the RTV. I coat both sides of the gasket with the Permatex RTV and then torque it to spec.
Wait atleast 12 hours before starting the car and you will be leak free.
Vic
To Simple Question........
